rsh.setsockopt events
Creating your file...
Your file is ready
rsh.setsockopt.failure
- Severity
ERROR
- Description
This message occurs when the setsockopt option on the RemoteShell(RSH) socket fails; RSH is not available.
- Corrective Action
Use the error message to determine the problem.
- Syslog Message
RSH setsockopt error: option level '%s', option value '%s', error code '%d', error message '%s'.
- Parameters
socketlevel (STRING): Socket option level parameter.
socketoption (STRING): Socket option value parameter.
errorcode (INT): Error code returned from setsockopt.
reason (STRING): Error message for the failure.
