sas.adapter events
Creating your file...
sas.adapter.bad.WWN
- Severity
ERROR
- Description
The base WWN associated with the SAS adapter is of invalid format. A correct WWN will be synthesized. The adapter will continue to function but this error indicates a manufacturing problem.
- Corrective Action
The controller should be replaced with a correctly programmed one.
- Syslog Message
The SAS WWN "%s" associated with adapter %s is bad. A valid one will be synthesized.
- Parameters
WWN (STRING): The bad WWN.
adapterName (STRING): The name of the associated SAS host bus adapter.
sas.adapter.debug
- Severity
INFORMATIONAL
- Description
The SAS adapter driver debug event.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
debug_string (STRING): The debug statement that occurred.
sas.adapter.failed
- Severity
ERROR
- Description
The SAS adapter driver could not recover the adapter after resetting it multiple times. The adapter will be put offline.
- Corrective Action
If the adapter is in use check cabling and if connected to disk shelves check the seating of IOM cards and disks. If the problem keeps occurring try replacing the adapter. Finally if the issue is still not resolved please contact NetApp technical support for assistance in diagnosing a SAS issue.
- Syslog Message
Failed to recover SAS %s after multiple resets. Offlining the adapter.
- Parameters
sas.adapter.firmware.download
- Severity
INFORMATIONAL
- Description
The firmware is being updated on the SAS adapter.
- Corrective Action
(None).
- Syslog Message
Updating firmware on SAS adapter %s from version %s to version %s.
- Parameters
oldFirmwareVersion (STRING): The version of the firmware currently on the adapter.
newFirmwareVersion (STRING): The version of the firmware being downloaded to the adapter.
sas.adapter.firmware.fault
- Severity
NOTICE
- Description
A firmware fault was detected on the SAS adapter and it is being reset to recover.
- Corrective Action
(None).
- Syslog Message
Detected firmware fault 0x%x on SAS adapter %s.
- Parameters
faultCode (INTHEX): The firmware fault code.
sas.adapter.firmware.update.failed
- Severity
EMERGENCY
- Description
The firmware on the SAS adapter was unable to be updated.
- Corrective Action
The adapter should be replaced as soon as possible. The SAS adapter driver will attempt to continue using the adapter without updating the firmware image.
- Syslog Message
Unable to update firmware on SAS adapter %s.
- Parameters
sas.adapter.not.ready
- Severity
ERROR
- Description
The SAS adapter did not become ready after being reset.
- Corrective Action
The SAS adapter driver will automatically attempt to recover from this error. If the error keeps occurring the adapter may need to be replaced.
- Syslog Message
SAS adapter %s did not become ready.
- Parameters
sas.adapter.offline
- Severity
INFORMATIONAL
- Description
The SAS adapter is now offline.
- Corrective Action
(None).
- Syslog Message
SAS adapter %s is now offline.
- Parameters
sas.adapter.offlining
- Severity
INFORMATIONAL
- Description
The SAS adapter is going offline after all outstanding I/O requests have finished.
- Corrective Action
(None).
- Syslog Message
Offlining SAS adapter %s.
- Parameters
sas.adapter.online
- Severity
INFORMATIONAL
- Description
The SAS adapter is now online.
- Corrective Action
(None).
- Syslog Message
SAS adapter %s is now online.
- Parameters
sas.adapter.online.failed
- Severity
ERROR
- Description
The SAS adapter failed to come online.
- Corrective Action
If the adapter is in use check cabling and if connected to disk shelves check the seating of IOM cards.
- Syslog Message
SAS adapter %s failed to come online.
- Parameters
sas.adapter.onlining
- Severity
INFORMATIONAL
- Description
The SAS adapter is in the process of going online.
- Corrective Action
(None).
- Syslog Message
Onlining SAS adapter %s.
- Parameters
sas.adapter.unexpected.status
- Severity
NOTICE
- Description
The SAS adapter returned an unexpected status and will be reset to recover.
- Corrective Action
(None).
- Syslog Message
Unexpected status 0x%x received from SAS adapter %s.
- Parameters
status (INTHEX): The status returned from the adapter.
sas.adapter.wwn.update.fail
- Severity
ERROR
- Description
This message occurs when the WWN, a unique world wide name that identifies the adapter, fails to update. This message only applies to internal lab systems.
- Corrective Action
Contact your administrator.
- Syslog Message
SAS adapter "%s" fails to update WWN "%s".
- Parameters
adapterName (STRING): Name of the associated SAS host bus adapter.
WWN (STRING): WWN of the associated SAS host bus adapter.
sas.adapter.wwn.updated
- Severity
NOTICE
- Description
This message occurs when an SAS host bus adapter's worldwide name (WWN) is updated successfully. The WWN is a unique name that identifies the serial-attached SCSI (SAS) host bus adapter.
- Corrective Action
(None).
- Syslog Message
SAS adapter "%s" WWN updated from "%s" to "%s"
- Parameters
OldWWN (STRING): Old WWN of the associated SAS host bus adapter.
WWN (STRING): New WWN of the associated SAS host bus adapter.
