sasmon.disable events
Creating your file...
Your file is ready
sasmon.disable.module
- Severity
INFORMATIONAL
- Description
This message occurs when the Data ONTAP® module responsible for monitoring Serial Attached SCSI (SAS) domain's transient errors is disabled due to the environment variable disable-sasmon? being set to "true".
- Corrective Action
Set the environment variable disable-sasmon? to "false" to enable this monitor module.
- Syslog Message
SAS domain is not monitoring transient errors.
- Parameters
(None).
