scsiblade.invalid events
Creating your file...
Your file is ready
scsiblade.invalid.xfer.len
- Severity
NOTICE
- Description
This message occurs when a SCSI command requests a transfer length greater than the LUN's maximum supported transfer length of 1MB. ONTAP® software completes the command normally but the host has sent this request in violation of the SCSI protocol.
- Corrective Action
Rescan the LUNs or reboot the host to enable discovery of the supported maximum transfer length for the LUN.
- Syslog Message
Host type %s sent command opcode 0x%x with a transfer length of %lld bytes, which exceeds the maximum of 1MB on LUN %s.
- Parameters
host_os_type (STRING): Host OS type.
opcode (INT): SCSI opcode.
length (LONGINT): Request transfer length.
LUNSerialNumber (STRING): Serial number of the LUN.
