ONTAP EMS reference
sis.undo events
sis.undo.aborted
Severity
ERROR
This messages occurs when a SIS volume 'undo' operation is aborted due to unexpected conditions.
Corrective Action
(None).
Syslog Message
SIS undo operation for '%s%s' has aborted: '%s'.
path (STRING): Path to a SIS volume.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
err (STRING): Error message.
sis.undo.aborted.inconsistent
Severity
ALERT
This message occurs when a SIS volume 'undo' operation is aborted due to volume inconsistency.
Corrective Action
Run wafliron to remove inconsistencies in the volume, then retry the operation.
Syslog Message
SIS 'undo' operation for '%s%s' has aborted due to volume inconsistencies.
sis.undo.done
Severity
NOTICE
This message occurs when 'sis undo -t wrong' command removes the sharing on improperly shared inodes.
Corrective Action
(None).
Syslog Message
The 'sis undo -t wrong' command removed sharings on improperly shared inodes in the volume '%s%s'. Details about cleaned inodes are available at '%s'.
volume (STRING): Volume name.
log_location (STRING): SIS undo log location.
sis.undo.nospace
Severity
ERROR
This event is issued to indicate that there is not enough free space to undo the shared blocks on a SIS volume. The undo operation will be aborted. Data blocks that were still shared at the time the undo operation stopped will remain shared. Blocks already processed by the undo operation are no longer shared.
Corrective Action
Free disk space in the volume, or increase the size of the volume, then retry the operation.
Syslog Message
Undoing shared blocks on volume %s%s has aborted because there is insufficient free space. Data blocks that were still shared at the time the undo operation stopped will remain shared. Blocks already processed by the undo operation are no longer shared.
vol (STRING): Path to a SIS volume
sis.undo.required
Severity
NOTICE
This message occurs when 'sis undo -t wrong -d' command finds improperly shared inodes.
Corrective Action
Run the 'sis undo -t wrong' or 'sis undo -i' command to remove improperly shared inodes.
Syslog Message
The 'sis undo -t wrong -d' command detected improperly shared inodes in the volume '%s%s'. Run the 'sis undo -t wrong' or 'sis undo -i' command to remove improperly shared inodes. Details about improperly shared inodes are available at '%s'.
sis.undo.started
Severity
INFORMATIONAL
This message occurs when a SIS undo operation is started.
Corrective Action
(None).
Syslog Message
SIS undo operation for %s%s has started.
volident (STRING): Uniquely identifies the volume when the volume name alone is insufficient.
sis.undo.stopped
Severity
ERROR
This event is issued when a SIS volume undo operation is stopped by user.
Corrective Action
(None).
Syslog Message
SIS undo operation for %s%s has stopped.
