sm.mediator events
sm.mediator.added
- Severity
NOTICE
- Description
This message occurs when ONTAP® Mediator is added successfully on a cluster.
- Corrective Action
(None).
- Syslog Message
ONTAP Mediator (version %s) is added on cluster '%s' having peer cluster '%s' and mediator IP address '%s'.
- Parameters
version (STRING): ONTAP Mediator version.
cluster (STRING): Cluster name on which ONTAP Mediator was added.
peerCluster (STRING): Peer cluster name.
ipAddress (STRING): ONTAP Mediator IP address.
sm.mediator.cacert.expired
- Severity
EMERGENCY
- Description
This message occurs when the ONTAP® Mediator certificate authority (CA) certificate has expired. As a result, all further communication to the ONTAP Mediator will not be possible.
- Corrective Action
Remove the configuration of the current ONTAP Mediator by using the "snapmirror mediator remove" command. Update a new CA certificate on the ONTAP Mediator server. Reconfigure access to the ONTAP Mediator by using the "snapmirror mediator add" command.
- Syslog Message
CA certificate of the ONTAP Mediator (IP: %s) expired on %s.
- Parameters
expiryDate (STRING): Expiry date of the ONTAP Mediator CA certificate.
sm.mediator.cacert.expiring
- Severity
ALERT
- Description
This message occurs when the ONTAP® Mediator certificate authority (CA) certificate is due to expire within the next 30 days.
- Corrective Action
Before this certificate expires, remove the configuration of the current ONTAP Mediator by using the "snapmirror mediator remove" command. Update a new CA certificate on the ONTAP Mediator server. Reconfigure access to the ONTAP Mediator by using the "snapmirror mediator add" command.
- Syslog Message
CA certificate for the ONTAP Mediator (IP: %s) will expire in %d days. Expiry: %s.
- Parameters
daysToExpire (INT): Number of days remaining until the certificate expires.
sm.mediator.clientc.expired
- Severity
EMERGENCY
- Description
This message occurs when the ONTAP® Mediator client certificate has expired. As a result, all further communication to the ONTAP Mediator will not be possible.
- Corrective Action
Remove the configuration of the current ONTAP Mediator by using the "snapmirror mediator remove" command. Reconfigure access to the ONTAP Mediator by using the "snapmirror mediator add" command.
- Syslog Message
Client certificate of the ONTAP Mediator (IP: %s) expired on %s.
- Parameters
expiryDate (STRING): Expiry date of the ONTAP Mediator client certificate.
sm.mediator.clientc.expiring
- Severity
ALERT
- Description
This message occurs when the ONTAP® Mediator client certificate is due to expire within the next 30 days.
- Corrective Action
Before this certificate expires, remove the configuration of the current ONTAP Mediator by using the "snapmirror mediator remove" command. Reconfigure access to the ONTAP Mediator by using the "snapmirror mediator add" command.
- Syslog Message
Client certificate for the ONTAP Mediator (IP: %s) will expire in %d days. Expiry: %s.
- Parameters
sm.mediator.in.quorum
- Severity
NOTICE
- Description
This message occurs when the ONTAP® Mediator connectivity is reestablished, its records are resynchronized and it is ready to participate in SnapMirror® Business Continuity (SMBC) quorum activities.
- Corrective Action
(None).
- Syslog Message
The ONTAP Mediator (IP: %s) connectivity is reestablished, its records are resynchronized and it is ready to participate in SMBC quorum activities. Peer cluster: %s.
- Parameters
sm.mediator.misconfigured
- Severity
ALERT
- Description
This message occurs when either the ONTAP® Mediator is repurposed or the Mediator package is no longer installed on the Mediator server. As a result, SnapMirror® failover is not possible.
- Corrective Action
- Syslog Message
ONTAP Mediator is not accessible on cluster "%s" with Mediator IP address "%s".
- Parameters
cluster (STRING): Name of the cluster that is attempting to access the ONTAP Mediator.
ipAddress (STRING): IP address of the ONTAP Mediator.
sm.mediator.removed
- Severity
NOTICE
- Description
This message occurs when ONTAP® Mediator is removed successfully from a cluster.
- Corrective Action
(None).
- Syslog Message
ONTAP Mediator (version %s) was removed on cluster '%s' having peer cluster '%s' and mediator IP address '%s'.
- Parameters
cluster (STRING): Cluster name on which ONTAP Mediator was removed.
sm.mediator.removed.force
- Severity
ERROR
- Description
This message occurs when ONTAP® Mediator is removed from a cluster using the "force" option. As a result, the ONTAP Mediator configuration might still be present on the peer cluster. This results in a partial configuration that could lead to the failure of a SnapMirror® failover operation.
- Corrective Action
Check whether the current ONTAP Mediator is configured on the peer cluster. If so, remove the ONTAP Mediator by using the (diagnostic privilege) "snapmirror mediator remove -force true" command. Reconfigure access to the ONTAP Mediator by using the "snapmirror mediator add" command.
- Syslog Message
ONTAP Mediator (IP: %s, version: %s) was removed using the "force" option on cluster %s. Peer cluster %s.
- Parameters
sm.mediator.resumed
- Severity
NOTICE
- Description
This message occurs when ONTAP® Mediator is resumed successfully on a cluster.
- Corrective Action
(None).
- Syslog Message
ONTAP Mediator was resumed on cluster '%s' having mediator IP address '%s'.
- Parameters
cluster (STRING): Cluster name on which ONTAP Mediator was resumed.
sm.mediator.serverc.expired
- Severity
EMERGENCY
- Description
This message occurs when the ONTAP® Mediator server certificate has expired. As a result, all further communication to the ONTAP Mediator will not be possible.
- Corrective Action
Remove the configuration of the current ONTAP Mediator by using the "snapmirror mediator remove" command. Update a new server certificate on the ONTAP Mediator server. Reconfigure access to the ONTAP Mediator by using the "snapmirror mediator add" command.
- Syslog Message
Server certificate of the ONTAP Mediator (IP: %s) expired on %s.
- Parameters
expiryDate (STRING): Expiry date of the ONTAP Mediator server certificate.
sm.mediator.serverc.expiring
- Severity
ALERT
- Description
This message occurs when the ONTAP® Mediator server certificate is due to expire within the next 30 days.
- Corrective Action
Before this certificate expires, remove the configuration of the current ONTAP Mediator by using the "snapmirror mediator remove" command. Update a new server certificate on the ONTAP Mediator server. Reconfigure access to the ONTAP Mediator by using the "snapmirror mediator add" command.
- Syslog Message
Server certificate for the ONTAP Mediator (IP: %s) will expire in %d days. Expiry: %s.
- Parameters
sm.mediator.suspended
- Severity
NOTICE
- Description
This message occurs when ONTAP® Mediator is suspended successfully on a cluster.
- Corrective Action
(None).
- Syslog Message
ONTAP Mediator was suspended on cluster '%s' having mediator IP address '%s'.
- Parameters
cluster (STRING): Cluster name on which ONTAP Mediator was suspended.
sm.mediator.unreachable
- Severity
ALERT
- Description
This message occurs when the ONTAP® Mediator is unreachable on a cluster. As a result, SnapMirror® failover is not possible.
- Corrective Action
Check the network connectivity to the ONTAP Mediator by using the "network ping" and "network traceroute" commands. If the issue persists, remove the configuration of the current ONTAP Mediator by using the "snapmirror mediator remove" command. Reconfigure access to the ONTAP Mediator by using the "snapmirror mediator add" command.
- Syslog Message
ONTAP Mediator (IP: %s) is unreachable from cluster %s.
- Parameters
sm.mediator.unusable
- Severity
ERROR
- Description
This message occurs when ONTAP® Mediator is unusable due to a corrupted mediator server database. If ONTAP Mediator is in this state, SnapMirror® failover will not be possible.
- Corrective Action
Remove ONTAP Mediator by using the "snapmirror mediator remove" command, and then add it again by using the "snapmirror mediator add" command.
- Syslog Message
ONTAP Mediator is unusable on cluster '%s' having mediator IP address '%s'.
- Parameters
cluster (STRING): Cluster name on which ONTAP Mediator is unusable.
