snapdiff.rebl events
Creating your file...
snapdiff.rebl.BadAccessTime
- Severity
NOTICE
- Description
This message occurs when SnapDiff®, the snapshot copy differencing engine, encounters an invalid access time for an inode. Future accesses of the inode should not only succeed, but also reset its access time to a valid value. Replication is also unaffected by this issue.
- Corrective Action
Run the (privilege: advanced) "inodepath -v volume_name inode_number" command to find the path of the affected file from the inode number, and modify the file within the Active File System. Note that file attributes captured in a snapshot copy cannot be changed.
- Syslog Message
Encountered invalid access time on inode %u in Snapshot copy ID %u of volume %u.
- Parameters
inode_num (INT): Identifier of the affected file.
snap_id (INT): Identifier of the Snapshot copy.
fsid (INT): Identifier of the volume.
snapdiff.rebl.BadModifyTime
- Severity
NOTICE
- Description
This message occurs when SnapDiff®, the snapshot copy differencing engine, encounters an invalid modification time for an inode. Future accesses of the inode should not only succeed, but also reset its modification time to a valid value. Replication is also unaffected by this issue.
- Corrective Action
- Syslog Message
Encountered invalid modify time on inode %u in Snapshot copy ID %u of volume %u.
- Parameters
