snaplock.disk events
Creating your file...
snaplock.disk.import.7mode
- Severity
ERROR
- Description
This message occurs when the configuration management detects that an older(7-Mode) version of a SnapLock® disk is attached to a system running a Data ONTAP® release that cannot support it.
- Corrective Action
Remove the SnapLock® disks from the system.
- Syslog Message
File system %s has SnapLock® disks. This version of Data ONTAP® does not support older(7-Mode) SnapLock® versions
- Parameters
disk_info (STRING): Formatted information about the disk.
shelf (STRING): Shelf identifier where the disk is located.
bay (STRING): Disk bay within the shelf where disk is located.
vendor (STRING): Name of the vendor of the disk.
model (STRING): Model string of the disk drive.
firmware_revision (STRING): Firmware revision number of the disk.
serialno (STRING): Serial number of the disk.
disk_type (INT): Type of disk drive.
disk_rpm (STRING): Rotational speed of disk in RPM.
failure_reason (STRING): A text description of storage error leading to disk failure.
carrier (STRING): Unique ID of the carrier in which the disk drive is installed.
site (STRING): For a MetroCluster® configuration, indicates the site ("Local" or "Remote") where the disk is located. For non-MetroCluster configurations, the site is "Local".
snaplock.disk.on.unsupported.version
- Severity
ERROR
- Description
This event is issued when configuration management detects that a SnapLock® disk is attached to a system running ONTAP® release which doesn't support SnapLock®.
- Corrective Action
Install a version of Data ONTAP that supports SnapLock, or remove the SnapLock disks.
- Syslog Message
File system %s has SnapLock disks. This version of Data ONTAP does not support SnapLock.
- Parameters
disk_info (STRING): Formatted information of the disk
site (STRING): For a MetroCluster configuration(tm), indicates the site {Local|Remote} where the disk is located. For non-MetroCluster configurations, site is 'Local'.
