snmp.authentication events
Creating your file...
Your file is ready
snmp.authentication.failure
- Severity
ERROR
- Description
This message occurs when there is an authentication failure during an SNMP query. This trap is generated for all SNMP versions.
- Corrective Action
In case of SNMPv1/v2c check whether the SNMP community string is configured. In case of SNMPv3, check whether SNMPv3 authentication credentials are correctly configured. The SNMPv3 credentials include username, password, authentication protocol, authentication protocol password, privacy protocol and privacy protocol password.
- Syslog Message
Authentication failure for SNMP query from port: %d.
- Parameters
interface (INT): Port on which the SNMP authentication failed.
