spm.hashd events
Creating your file...
Your file is ready
spm.hashd.process.exit
- Severity
ALERT
- Description
This message occurs when the hashd server (hashd) involuntarily terminates.
- Corrective Action
The system attempts to recover by restarting the hashd process server. If the process does not restart within the threshold number of retries, then an AutoSupport message is sent. If your system is not configured to send AutoSupport messages and the issue persists, contact technical support.
- Syslog Message
The hashd server (hashd) with ID %d exited as a result of %s. This server will attempt to restart.
- Parameters
id (INT): Process identifier.
cause (STRING): Plain text description of why the process exited.
