ONTAP EMS reference
vifmgr.extroute events
vifmgr.extRoute.addTable
Severity
NOTICE
This message occurs when a new external route table is added successfully.
Corrective Action
(None).
Syslog Message
External route table %s was added successfully.
table (STRING): Route table name.
vifmgr.extRoute.ipCreate
Severity
NOTICE
This message occurs when a LIF was successfully added to or updated in external route tables.
Corrective Action
(None).
Syslog Message
LIF with IP address %s is mapped to external port ID %s in external route tables.
vifip (STRING): IP address of the logical interface.
extportid (STRING): External port ID on which this LIF was created.
vifmgr.extRoute.ipDelete
Severity
NOTICE
This message occurs when a LIF was successfully deleted from external route tables.
Corrective Action
(None).
Syslog Message
LIF with IP address %s was removed from external route tables.
vifmgr.extRoute.ipMove
Severity
NOTICE
This message occurs when a LIF was successfully moved to a new external port ID in external route tables.
Corrective Action
(None).
Syslog Message
LIF with IP address %s was moved to external port ID %s in external route tables.
extportid (STRING): External port ID to which this LIF was moved.
vifmgr.extRoute.noAddTable
Severity
NOTICE
This message occurs when a new external route table cannot be added.
Corrective Action
(None).
Syslog Message
Failed to add external route table %s (error %s).
error (STRING): Error that was reported.
vifmgr.extRoute.noConn
Severity
ERROR
This message occurs when the system cannot verify connectivity to the external mediator server.
Corrective Action
Use the "network route show -vserver Cluster" command to verify that a suitable route exists to the mediator. Ensure that the external network security configuration enables communication between all nodes and the mediator.
Syslog Message
Failed to verify connectivity with the mediator server, IP %s (error %s).
mediatorip (STRING): IP address of the mediator.
vifmgr.extRoute.noIpCreate
Severity
ERROR
This message occurs when a LIF cannot be added to or updated in external route tables.
Corrective Action
If an entry is found in the external route tables for the given IP address and external port ID, remove that entry from the tables using the tools provided by the cloud provider. Note that any subsequent LIF created with the same IP address will replace any entry remaining in the external route table.
Syslog Message
Failed to successfully map LIF with IP address %s to external port ID %s in external route tables (error %s).
extportid (STRING): External port ID on which this LIF was to be created.
vifmgr.extRoute.noIpDelete
Severity
NOTICE
This message occurs when a LIF cannot be removed from external route tables.
Corrective Action
(None).
Syslog Message
Failed to remove LIF with IP address %s from external route tables (error %s).
vifmgr.extRoute.noIpMove
Severity
NOTICE
This message occurs when a LIF cannot be moved to a new external port ID in external route tables or to a different subnet.
Corrective Action
(None).
Syslog Message
Failed to move LIF. Error: %s
vifmgr.extRoute.noRmTable
Severity
NOTICE
This message occurs when an external route table cannot be removed.
Corrective Action
(None).
Syslog Message
Failed to remove external route table %s (error %s).
vifmgr.extRoute.rmTable
Severity
NOTICE
This message occurs when an external route table is removed.
Corrective Action
(None).
Syslog Message
External route table %s was removed successfully.
