wafl.32bit events
Creating your file...
Your file is ready
wafl.32bit.formatUnsupported
- Severity
ERROR
- Description
This message occurs when an aggregate or volume with a 32-bit or mixed format file system is found. These formats are unsupported in this version of Data ONTAP®, and the volume cannot be brought online.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
%s %s%s%s%s has an unsupported 32-bit or mixed format file system (Snapshot copy ID %u).
- Parameters
type (STRING): Type of object (volume or aggregate).
owner (STRING): Volume owner.
vol (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): Unique identifier of the volume in cases where the volume name itself is insufficient.
snapid (INT): Snapshot(tm) copy identifier: (0) - active file system (non-zero) - refers to Snapshot copy
