wafl.dosname events
Creating your file...
wafl.dosname.repair.fail
- Severity
ERROR
- Description
This message occurs when the system cannot correct duplicate dosnames present in a directory.
- Corrective Action
From the NFS client, check the directory for file or subdirectory names like {}. Rename these, and then run (privilege diag) the "wafl dosname" node shell command on the directory.
- Syslog Message
Dosname repair failed for file ID: %d volume %s:%s.
- Parameters
fileid (INT): Directory file ID where dosname repair failed.
vserver_uuid (STRING): Universal Unique ID (UUID) of the volume's Vserver.
volume (STRING): Volume name.
wafl.dosname.repair.success
- Severity
NOTICE
- Description
This message occurs when the "wafl dosname" command is completed successfully.
- Corrective Action
(None).
- Syslog Message
"wafl dosname" command successfully completed on volume %s:%s. Total files corrected: %d.
- Parameters
total (INT): Total number of directory entries changed.
