wafl.giveback events
Creating your file...
wafl.giveback.create.fail
- Severity
ERROR
- Description
This message occurs when the system cannot perform a giveback due to vol create, and must abort giveback.
- Corrective Action
A volume is being created. Wait for volume creation to finish and then retry giveback.
- Syslog Message
%s %s%s%s%s is being created; canceling giveback.
- Parameters
type (STRING): Type of object (volume or aggregate).
owner (STRING): Volume owner.
vol (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
wafl.giveback.fence.fail
- Severity
ERROR
- Description
This message occurs when the system cannot perform a giveback operation because a fence is set on one of the volumes in the aggregate. The giveback operation is aborted.
- Corrective Action
A volume in the aggregate is currently fenced for group operations. Retry giveback after any group SnapRestore® or mirror transfers are complete. If the problem persists, contact technical support.
- Syslog Message
%s %s%s%s%s has a fence set; canceling giveback.
- Parameters
volident (STRING): Unique volume identity when the volume name itself is insufficient.
wafl.giveback.iron.fail
- Severity
ERROR
- Description
This message occurs when the system cannot perform a giveback due to wafliron, and must abort giveback.
- Corrective Action
(Call support).
- Syslog Message
%s %s%s%s%s has vol wafliron start underway; canceling giveback.
- Parameters
wafl.giveback.sp.fail
- Severity
ERROR
- Description
This message occurs when the system cannot perform a giveback operation because a secure purge operation is being performed on one of the volumes in the aggregate. The giveback operation is aborted.
- Corrective Action
A volume in the aggregate is undergoing a secure purge operation. Retry giveback after this operation is complete, or after you abort the operation by using the "volume encryption secure-purge abort" command. If the problem persists, contact NetApp technical support.
- Syslog Message
A secure purge operation is in progress on %s %s%s%s. Canceling giveback.
- Parameters
wafl.giveback.statusvol.fail
- Severity
ERROR
- Description
This message occurs when the system cannot perform a giveback due to the volume being used to host wafliron status files.
- Corrective Action
Use "aggr wafliron show" command to monitor the status of wafliron and retry giveback after the completion of wafliron that uses the status files hosting volume.
- Syslog Message
%s %s%s%s%s is being used by wafliron to host status files. Canceling giveback.
- Parameters
wafl.giveback.vetoedByNvsave
- Severity
ERROR
- Description
This message occurs when a high-availability (HA) giveback is vetoed because there are NVSave files for an aggregate or a flexible volume that must be replayed before the aggregate or flexible volume can be given back.
- Corrective Action
Retry the giveback operation after the NVSave files either are replayed (by bringing the aggregate or flexible volume online) or are deleted from the root volume. Successful replay, for example, is indicated by the EMS message 'wafl.nvsave.replaying.pass'.
- Syslog Message
Giveback vetoed because NVSave files are present for %s FSID %d name %s%s%s. UUID is %s.
- Parameters
vol_type (STRING): Whether this message refers to NVSave files for an aggregate or a flexible volume.
fsid (INT): File system identifier.
volident (STRING): Unique identifier of the volume in cases in which the volume name itself is insufficient.
UUID (STRING): UUID of the volume.
