wafl.ino events
Creating your file...
wafl.ino.upgrade.aborted
- Severity
INFORMATIONAL
- Description
This message occurs when an inode upgrade for the specified WAFL volume or aggregate is aborted.
- Corrective Action
(None).
- Syslog Message
Inode upgrade of volume or aggregate '%s %s' has been aborted.
- Parameters
owner (STRING): Owner of the volume or aggregate.
volname (STRING): Name of the volume or aggregate.
wafl.ino.upgrade.cantAbort
- Severity
NOTICE
- Description
This message occurs when an attempt to abort the inode upgrade scan by using the "wafl scan abort" command. The inode upgrade scan cannot be interrupted.
- Corrective Action
Wait for the inode upgrade to finish or use the "{ vol | aggr } inode-upgrade suspend" command to stop the scan.
- Syslog Message
User cannot abort the inode upgrade scan. Use the '{ vol | aggr } inode-upgrade suspend' command.
- Parameters
(None).
wafl.ino.upgrade.completed
- Severity
INFORMATIONAL
- Description
This message occurs when the inode upgrade of the specified WAFL volume or aggregate is complete.
- Corrective Action
(None).
- Syslog Message
An inode upgrade to version %d for volume or aggregate '%s %s' has completed.
- Parameters
to_version (INT): Version the inode upgraded to.
wafl.ino.upgrade.disabled
- Severity
ALERT
- Description
This message occurs when the inode upgrade is disabled on the node via the "wafl_v4ino_upgrade_disable" bootarg. All aggregates and volumes are still usable, but there might be some features that cannot be enabled on certain volumes until the inode upgrade is completed on those volumes.
- Corrective Action
Contact technical support for assistance.
- Syslog Message
Inode upgrade is disabled on this node.
- Parameters
(None).
wafl.ino.upgrade.rem.mdata
- Severity
INFORMATIONAL
- Description
This message occurs when inode upgrade metadata was removed either by administrator actions or due to wafliron.
- Corrective Action
(None).
- Syslog Message
Inode upgrade metadata for volume or aggregate '%s %s' has been removed.
- Parameters
wafl.ino.upgrade.resumed
- Severity
INFORMATIONAL
- Description
This message occurs when an inode upgrade of the specified WAFL volume or aggregate is resumed.
- Corrective Action
(None).
- Syslog Message
An inode upgrade for volume or aggregate '%s %s' was resumed.
- Parameters
wafl.ino.upgrade.stalled
- Severity
NOTICE
- Description
This message occurs when the administrator suspended an inode upgrade for the specified WAFL volume or aggregate sometime in the past. The volume or aggregate is still usable, but there might be some features that cannot be enabled until the inode upgrade is complete.
- Corrective Action
Use the command 'volume inode-upgrade resume "volume"' or 'storage aggregate inode-upgrade resume "aggregate"' to resume the upgrade.
- Syslog Message
Inode upgrade of volume or aggregate '%s %s' is suspended.
- Parameters
wafl.ino.upgrade.started
- Severity
INFORMATIONAL
- Description
This message occurs when the inode upgrade for the specified WAFL volume or aggregate begins.
- Corrective Action
(None).
- Syslog Message
An inode upgrade from version %d for volume or aggregate '%s %s' has begun.
- Parameters
from_version (INT): Current inode version.
wafl.ino.upgrade.susp
- Severity
INFORMATIONAL
- Description
This message occurs when an inode upgrade for the specified WAFL volume or aggregate is suspended by the administrator or because wafliron is running. The volume or aggregate is still usable, but there might be some features that cannot be enabled until the inode upgrade is complete.
- Corrective Action
(None).
- Syslog Message
An inode upgrade for volume or aggregate '%s %s' was suspended. Reason %s. Metadata was %s.
- Parameters
reason (STRING): Reason the upgrade was suspended.
metadata_removed (STRING): Atring indicating whether metadata was removed as part of the suspension.
wafl.ino.upgrade.susp.nospc
- Severity
ERROR
- Description
This message occurs when an inode upgrade for the specified WAFL volume or aggregate is suspended due to a lack of space. The volume or aggregate is still usable, but there might be some features that cannot be enabled until the inode upgrade is complete.
- Corrective Action
Ensure that the volume or aggregate has at least as many bytes available for use as indicated by 'space_required'. Simply add the space to the volume and the upgrade is automatically retried.
- Syslog Message
An inode upgrade for volume or aggregate '%s %s' was suspended due to a lack of space (space required: %d bytes).
- Parameters
space_required (LONGINT): Estimated amount of disk space required, in bytes, to complete the upgrade.
