wafl.iron events
wafl.iron.7mode
Severity
ERROR
This message occurs when wafliron is running on a transitioned aggregate in precommit phase and there are 7-Mode volumes present. Wafliron ignores the 7-Mode volumes.
Corrective Action
Run the "storage transition aggregate start" command to convert the aggregate to a cluster aggregate.
Syslog Message
Transitioned aggregate %s has 7-Mode volumes which cannot be ironed.
aggrname (STRING): Name of the aggregate.
wafl.iron.abort.noConToCloud
Severity
EMERGENCY
This message occurs when the file system consistency checker (wafliron) aborts because the connection to the cloud service provider is not available.
Corrective Action
Restore the connection to the cloud service provider, then retry the "aggr wafliron start <aggr_name>" command.
Syslog Message
File system consistency checker aborted on aggregate "%s". The connection to the cloud service provider is not available.
aggrname (STRING): Aggregate name.
wafl.iron.abort.offline
Severity
NOTICE
This message occurs when wafliron is aborted and the aggregate or volume is taken offline. This will occur if the aggregate or volume is inconsistent at the time of abort or if wafliron was invoked in optional commit mode. If wafliron was invoked in optional commit mode, all changes are rejected because they might not be consistent.
Corrective Action
No corrective action is required for this notification event. Wafliron automatically takes an inconsistent aggregate or volume offline. Wafliron automatically takes the aggregate offline in optional commit mode.
Syslog Message
Wafliron was aborted on %s%s '%s'; the aggregate or volume was taken offline.
volinfo (STRING): Descriptive information about the volume, such as whether it was inconsistent when taken offline.
voltype (STRING): Aggregate or flexible volume.
aggrname (STRING): Aggregate or flexible volume name.
wafl.iron.abort.offlineFail
Severity
NOTICE
This message occurs when wafliron is aborted and taking an inconsistent aggregate or volume offline was not successful.
Corrective Action
(Call support).
Syslog Message
Wafliron abort failed to take offline inconsistent %s '%s': %s.
errmsg (STRING): Error message.
wafl.iron.abort.offlineMsg
Severity
NOTICE
This message occurs when the wafliron operation is aborted. Taking the aggregate offline was not successful.
Corrective Action
(None).
Syslog Message
Wafliron abort on %s '%s': %s.
voltype (STRING): Aggregate.
wafl.iron.backup.exists
Severity
NOTICE
This message occurs when a SnapIron backup image already exists on the volume. Wafliron will continue to run without creating another SnapIron backup image.
Corrective Action
(Call support).
Syslog Message
A SnapIron backup image %s already exists on %s.
vol (STRING): Volume name.
name (STRING): Name of the backup image.
wafl.iron.backup.expired
Severity
INFORMATIONAL
This message occurs when a SnapIron backup image expires and will be deleted.
Corrective Action
(None).
Syslog Message
The SnapIron backup image %s of %s expired.
name (STRING): Name of the backup image being deleted.
wafl.iron.backup.expiring
Severity
NOTICE
This message occurs when a SnapIron backup image is close to expiring.
Corrective Action
Pay attention to the integrity of the data on this volume before the backup image expires and is subsequently deleted by automatic deletion of aggregate Snapshot copies. Contact NetApp technical support.
Syslog Message
The SnapIron backup image %s of %s will expire in %d hour(s).
hours (INT): Number of hours remaining from the lifetime of the backup image.
wafl.iron.backup.impossible
Severity
NOTICE
This message occurs when wafliron encounters a problem when creating a SnapIron backup image. The message explains the reason. Wafliron will continue to run without the SnapIron backup image.
Corrective Action
(None).
Syslog Message
Wafliron could not create a SnapIron backup image on %s, %s.
reason (STRING): Reason for not being able to create a SnapIron backup image.
wafl.iron.backup.removed
Severity
NOTICE
This message occurs when a SnapIron backup image is removed. Wafliron will continue to run without a SnapIron backup image if it is running.
Corrective Action
(None).
Syslog Message
The SnapIron backup image %s of %s was deleted.
wafl.iron.backup.rst.failed
Severity
ALERT
The message occurs when the system cannot restore the aggregate from the wafliron backup image. The active file system will be loaded.
Corrective Action
Syslog Message
Failed to restore %s %s%s%s%s from its wafliron backup image (ID %d). The active file system will be loaded.
type (STRING): Type of object (volume or aggregate).
owner (STRING): Owner of the volume.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
id (INT): Backup image ID.
reason (STRING): Reason for the failure.
wafl.iron.backup.rst.noExist
Severity
NOTICE
The message occurs when the system cannot restore the aggregate from the wafliron backup image because the image does not exist. The active file system will be loaded.
Corrective Action
(None).
Syslog Message
Could not restore %s %s%s%s%s from its wafliron backup image because the image does not exist. The active file system will be loaded.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
wafl.iron.backup.rst.success
Severity
INFORMATIONAL
The message occurs when the system restores the aggregate from its wafliron backup image.
Corrective Action
(None).
Syslog Message
Restored %s %s%s%s%s from its wafliron backup image (ID %d).
wafl.iron.backup.snaprsv.inc
Severity
INFORMATIONAL
This message occurs when wafliron tries to increase the Snapshot(tm) reserve of the aggregate temporarily to allow keeping the SnapIron backup image longer. The message shows whether the attempt was successful.
Corrective Action
(None).
Syslog Message
The attempt to increase Snapshot copy reserve of %s temporarily from %d percent by %d %s.
rsv (INT): Old value of the aggregate Snapshot reserve, in percentage.
delta (INT): Change in the new value of the aggregate Snapshot copy reserve, in percentage. If the Snapshot copy reserve was successfully increased, it will be returned to its original value automatically after the SnapIron backup image expires, the new snapshot reserve space becomes full again, or the snapshot is deleted. In the latter case, the SnapIron backup image will be deleted by automatic deletion of aggregate Snapshot copies.
result (STRING): Whether the attempt was successful.
wafl.iron.backup.snaprsv.rst
Deprecated
This is deprecated as success doesn't require any action failure can never happen.
Severity
NOTICE
This message occurs when the Snapshot(tm) reserve of the aggregate, which was temporarily increased by wafliron, is restored to its original value.
Corrective Action
If wafliron fails to return the volume's Snapshot copy reserve to the original value, contact NetApp technical support.
Syslog Message
The reset of Snapshot reserve value of %s by %d from %d was %s.
val (INT): Current value of the aggregate Snapshot copy reserve, in percentage.
delta (INT): Change in the value of the aggregate Snapshot reserve, in percentage.
wafl.iron.backup.success
Severity
INFORMATIONAL
This message occurs when wafliron creates a SnapIron backup image.
Corrective Action
(None).
Syslog Message
Wafliron created SnapIron backup image %s on volume %s, ID %d.
name (STRING): Backup image name.
wafl.iron.backup.useimage
Severity
INFORMATIONAL
This message occurs when wafliron is using a SnapIron backup image to check the file system.
Corrective Action
(None).
Syslog Message
Wafliron is using SnapIron backup image of %s (ID %u).
id (INT): ID of SnapIron backup image.
wafl.iron.backup.verify.data
Severity
NOTICE
This message occurs when wafliron creates a SnapIron backup image and you need to verify whether user data is stored in the aggregate or volume as soon as possible.
Corrective Action
Validate the user data stored in the aggregate or volume as soon as possible, before the SnapIron backup image is deleted. Contact NetApp technical support.
Syslog Message
Verify user data of %s.
wafl.iron.badfsid
Severity
ALERT
This message occurs when a flexible volume has an invalid file system ID(FSID). Wafliron skips this volume.
Corrective Action
Syslog Message
Flexible volume %s%s%s on aggregate %s has an invalid FSID (%08x).
volname (STRING): Volume name.
fsid (INT): File system identifier.
wafl.iron.completion.times
Severity
INFORMATIONAL
This event provides the time taken to complete the different phases of Wafliron.
Corrective Action
(None).
Syslog Message
%s phase of %s %s took %s.
p (STRING): Name of the iron phase.
ty (STRING): Type of the volume.
v (STRING): Name of the volume.
t (STRING): Time taken for the phase.
wafl.iron.cont.corrupt
Severity
ALERT
This message occurs when a volume granular wafliron operation running on an aggregate finds corruption in the container file of a volume on which wafliron is not being run.
Corrective Action
Contact Contact NetApp technical support..
Syslog Message
Volume granular wafliron is in progress on aggregate %s. Corruption was found in volume %s container file with file id %d in which wafliron might have not run.
aggr_name (STRING): Name of the aggregate on which wafliron is running.
vol_name (STRING): Name of the volume in which corruption was found in the container file.
container_file_id (INT): File id of container file of the volume in which corruption was found.
wafl.iron.current.phase
Severity
INFORMATIONAL
This message specifies the phase name that wafliron is currently working on.
Corrective Action
(None).
Syslog Message
wafliron is active on %s %s : %s.
phase (STRING): Name of the current wafliron phase.
wafl.iron.dp.mirror.broken
Severity
ERROR
This message occurs when a Data Protection mirrored volume is broken from its SnapMirror® relationship as a result of starting wafliron with the '-include-mirrors' option. When this happens, the Volume Location Database (VLDB), which is managed by the management host, must also be updated manually after wafliron finishes to avoid any discrepancy between the VLDB and Dblade.
Corrective Action
Run the 'debug vreport' command to resolve the inconsistency in the VLDB. Step 1) run 'debug vreport show' to show the object name. Step 2) run 'debug vreport fix -type volume -object object-name'.
Syslog Message
WaflIron broke the SnapMirror® relationship for volume '%s%s%s'. Use the 'debug vreport' command to resolve inconsistencies before reestablishing the SnapMirror relationship.
wafl.iron.grow.fs.failed
Severity
ERROR
This message occurs when WAFL® cannot grow a volume or aggregate because wafliron is running and the root volume does not have enough free space to grow the iron status files.
Corrective Action
Check the free space in the root volume. Abort wafliron or grow the root volume to accommodate the grown status files
Syslog Message
WAFL failed to grow %s %s due to a failure in growing wafliron status files in the root volume.
voltype (STRING): Volume type: volume or aggregate.
volname (STRING): Name of the volume or aggregate.
wafl.iron.i2p.dir.convert
Severity
INFORMATIONAL
This message occurs to inform you why wafliron is starting the inode-to-parent (i2p) initialization scan. The i2p scan updates the information in the volume necessary to perform i2p path name translations. The reason i2p information needs updating is that the volume contains converted directories, and the entries in the converted directories need their i2p information updated. This message does not indicate anything abnormal or problematic.
Corrective Action
(None).
Syslog Message
Found converted directories in %s %s%s%s%s that require their entry's inode-to-parent (i2p) information updated. Starting the i2p initialization scanner to update the entries in the converted directories. This is normal.
type (STRING): Type of object (volume/aggregate).
owner (STRING): Volume owner.
wafl.iron.incompleteVol
Severity
ALERT
This wafliron event indicates that a volume is partially created and might be in an inconsistent state. Wafliron is marking the volume as unrecoverable. For instance, if filer panics before snap restore completes when a clone volume is created it may leave the volume partially created.
Corrective Action
If the volume is known not to contain any valuable data, it can be safely destroyed and recreated.
Syslog Message
Flexible volume %s%s on aggregate %s is partially created. Marking it unrecoverable. You may destroy this volume and recreate it.
wafl.iron.invalid.vvol
Severity
ERROR
This wafliron message indicates that a volume is invalid. Wafliron cannot run on invalid volumes. A volume can become invalid as a result of an aborted 'vol copy' operation or SnapMirror® initial transfer. To bring the volume back online, you must re-create it through a completed 'vol copy' operation or SnapMirror transfer.
Corrective Action
If you know that the volume does not contain any valuable data, you can safely destroy and re-created it.
Syslog Message
Flexible volume %s%s%s on aggregate %s is invalid. Wafliron cannot run on invalid volumes.
volident (STRING): Unique identifier of the volume in cases where the volume name itself is insufficient.
wafl.iron.lost.blocks
Severity
INFORMATIONAL
This message indicates that wafliron is running on a particular inode.
Corrective Action
(None).
Syslog Message
Wafliron on %s %s%s%s is verifying %lld %s inode now.
voltype (STRING): Volume type.
volident (STRING): Unique identifier of the volume when the volume name by itself is insufficient.
inode_number (LONGINT): Number of inode buftrees not verified.
ino_type (STRING): The inode type.
wafl.iron.manualUpgradeRequired
Severity
ERROR
This event is issued when wafliron can't run on the volume because it's not upgraded yet. This happens when system was upgraded with an offlined or restricted volume (possibly due to corruption) and wafliron is started after the upgrade with the volume offlined or restricted.
Corrective Action
Manually online the volume and then restart wafliron. Or fix any corruption on an inconsistent volume and bring it online before a kernel upgrade.
Syslog Message
Wafliron cannot run on volume '%s' that is in an older format. Manually online the volume and retry wafliron.
wafl.iron.mount.inconsistency
Severity
ERROR
This message occurs when wafliron finds some WAFL® inconsistency issues on an aggregate during mount.
Corrective Action
Run the 'storage aggregate wafliron review <aggregate-name>' command to review the issues that wafliron found. If you need assistance resolving any of the issues, contact NetApp technical support.
Syslog Message
wafliron on aggregate %s found some WAFL inconsistency issues during mount.
wafl.iron.mount.inconsistent
Severity
ALERT
This wafliron message indicates that the FlexVol® volume cannot be mounted; the volume is marked as inconsistent.
Corrective Action
Re-run wafliron with the '-prev_cp' option set to restore the FlexVol volume to the closest Consistency Point(CP)/Snapshot(tm) copy.
Syslog Message
wafliron could not mount volume %s due to %s. Volume is marked as inconsistent.
vvolname (STRING): Volume name.
wafl.iron.mount.times
Severity
INFORMATIONAL
This message prints the mount times taken by the different phases of aggregate mount during wafliron. This message occurs after wafliron completion or through a wafliron status message.
Corrective Action
(None).
Syslog Message
%s mount phase of %s %s took %s.
phase (STRING): Name of the mount phase.
voltype (STRING): Type of the volume (aggergate/flexvol).
time (STRING): Time taken for the phase.
wafl.iron.mounted.volume
Severity
INFORMATIONAL
This message is used to print on the console that the volume is mounted during wafliron.
Corrective Action
(None).
Syslog Message
Wafliron mounted volume %s.
wafl.iron.mw.ioc.not.supported
Severity
ERROR
This event is issued when IOC is issued on metawafl aggregate.
Corrective Action
(Call support).
Syslog Message
Iron optional commit is not supported on metawafl aggregate '%s'. Please run wafliron.
wafl.iron.nvsave.disable.selection
Severity
INFORMATIONAL
This message is used to print on the console that the wafliron cannot run in volume select mode on the aggr as the aggregate has nvsave file records.
Corrective Action
(None).
Syslog Message
The aggr %s has nvlog records in the system. Wafliron cannot run in volume selection mode. Volumes will be brought online in random order.
aggr (STRING): Name of the aggregate.
wafl.iron.oc.abort.bad_blk
Severity
EMERGENCY
This message occurs when the system aborts wafliron in optional commit mode on the volume due to a bad block in the change log and lost write context status files.
Corrective Action
Refer to the Recovery Decision Tree.
Syslog Message
Aborting wafliron in optional commit mode because a bad block was found in volume '%s'.
wafl.iron.oc.abort.clog_full
Severity
EMERGENCY
This message occurs when the system aborts an optional commit wafliron operation on a volume because the change log file was full, due to extensive filesystem consistency changes.
Corrective Action
Syslog Message
Aborting wafliron in optional commit mode on aggregate '%s'. The change log is full.
wafl.iron.oc.committedChangeLog
Severity
NOTICE
This wafliron event indicates that optional commit change log files have been committed to disk.
Corrective Action
This happens when the user explicitly commits the changes to disk.
Syslog Message
Committed change log files for aggregate %s.
wafl.iron.oc.deletedChangeLog
Severity
EMERGENCY
This wafliron event indicates that optional commit change log files have been deleted.
Corrective Action
This happens when the change log files have been writted to disk, or have been rejected.
Syslog Message
Deleted change log files for aggregate %s.
wafl.iron.oc.errorCommitLog
Severity
EMERGENCY
This wafliron event indicates that optional commit change log files' commit process has encountered an error.
Corrective Action
Corrective action may include offlining the aggregate and running wafliron in optional commit mode again.
Syslog Message
Error committing change log files for aggregate %s.
wafl.iron.oc.noCorruption
Severity
NOTICE
This wafliron event indicates that optional commit did not find any corruption in the aggregate that it is being run on.
Corrective Action
No corrective action is required for this notification event. Wafliron will automatically online the aggregate.
Syslog Message
Wafliron did not find any corruption on aggregate %s. The aggregate and its volumes will be offlined automatically.
wafl.iron.oc.rejectChangeLog
Severity
NOTICE
This wafliron event indicates that optional commit change log files have been rejected (not committed).
Corrective Action
No corrective action required for this notification event.
Syslog Message
Rejecting change log files for aggregate %s.
wafl.iron.oc.root.committedChanges
Severity
NOTICE
This wafliron event indicates that optional commit changes have been committed to disks of the root aggregate/tradvol.
Corrective Action
No corrective action required.
Syslog Message
Committed changes for %s '%s'. The system will reboot now.
voltype (STRING): Volume type - aggregate or tradvol
wafl.iron.oc.root.lowMemory
Severity
EMERGENCY
Wafliron Optional Commit on the Root has exhausted available memory and cannot continue. Options will be presented to the administrator to either abort the changes or write to disk.
Corrective Action
Changes will have to be committed to disk for wafliron to continue or will have to be rejected.
Syslog Message
Wafliron Optional Commit on '%s' has run out of available memory and cannot continue. Please either commit to continue Wafliron by writing changes to disk or reject the changes (which will reboot the system).
wafl.iron.oc.root.noCorruption
Severity
NOTICE
This wafliron message indicates that the optional commit operation does not find any corruption in the root aggregate that it is being run on.
Corrective Action
No corrective action is required.
Syslog Message
Wafliron did not find any corruption on aggregate %s. The system will reboot now.
aggrname (STRING): Root aggregate name.
wafl.iron.oc.root.rejectedChanges
Severity
NOTICE
This wafliron event indicates that optional commit changes have been rejected.
Corrective Action
Syslog Message
Rejected changes for %s '%s'. The system will reboot now.
wafl.iron.offline.destroying
Severity
INFORMATIONAL
This message occurs when a volume is being destroyed and cannot be ironed/onlined.
Corrective Action
(None).
Syslog Message
Volume '%s%s%s' is being destroyed and was taken offline.
wafl.iron.optcommit.upgradeScan
Severity
ERROR
This message occurs when wafliron optional commit is started in a volume that has an upgrade still in progress.
Corrective Action
Wait for the upgrade scanner to finish for this volume, then restart wafliron.
Syslog Message
Wafliron optional commit cannot run in volume '%s' that still has an upgrade in progress. Run the advanced CLI command 'wafl scan status' to check whether an upgrade is still in progress.
wafl.iron.outofspace
Severity
ERROR
This message oocurs when an aggregate is out of space. Wafliron omits the volumes in this aggregate when managing the aggregate.
Corrective Action
Run the "storage transition commit start" command to commit the aggregate transition and delete the pinned Snapshot® copy.
Syslog Message
Volumes in the aggregate %s are kept offline since aggregate is out of space. Wafliron omits volumes in this aggregate.
wafl.iron.parallel.mount.notify
Severity
NOTICE
This message indicates that wafliron parallel mount is proceeding for the flexible volumes in an aggregate. All sparse volumes are mounted in parallel first, followed by non-clone flexible volumes in parallel. Each clone is mounted following its parent volume.
Corrective Action
(None).
Syslog Message
Wafliron parallel mount enabled. Wafliron is mounting flexible volumes in parallel in the aggregate %s.
aggr (STRING): Aggregate name
wafl.iron.parent.volume.selected
Severity
INFORMATIONAL
This message occurs when the parent of a clone volume is added to the list of volumes wafliron will mount first because the clone volume is on the list.
Corrective Action
(None).
Syslog Message
Volume %s in aggregate %s was added to the list of volumes that wafliron will mount first because its clone volume %s is present in this list.
parent_volume (STRING): Name of the parent volume.
clone_volume (STRING): Name of the clone volume.
wafl.iron.pending.delete.vvol
Severity
ERROR
This wafliron event indicates that a volume is awaiting deletion and cannot be ironed/onlined. It's deletion also cannot be canceled while iron is running, so its retention time may need to be extended in order to keep the volume.
Corrective Action
If you do not want the volume to be deleted while iron is running, check the retention time and consider extending it.
Syslog Message
Flexible volume %s%s%s on aggregate %s is awaiting deletion. Wafliron cannot run on such volumes.
wafl.iron.ral.exception
Severity
ERROR
This message occurs when wafliron is loading an inode that has a remote entry, but the corresponding remote volume is not reachable.
Corrective Action
Inspect the status of the FlexGroup remote volume, which might be down due to network errors, cluster node failures, or corruption in one or more of its constituent aggregates. Also check the health and connectivity of all nodes that are hosting these aggregates.
Syslog Message
Wafliron could not load inode "%d" on volume "%s" because the remote volume is not accessible.
inode (INT): Inode that could not be loaded.
volume (STRING): Volume being inspected by wafliron.
wafl.iron.ral.inode.loaded
Severity
NOTICE
This message occurs when wafliron succeeds in loading an inode in a FlexGroup origin volume that was not reachable earlier.
Corrective Action
NONE.
Syslog Message
After several retries, wafliron has processed inode "%d" in volume "%s".
inode (INT): Inode loaded after retries.
wafl.iron.readonly
Severity
NOTICE
This message occurs during wafliron volume initialization, indicating that read-only volumes might not be checked.
Corrective Action
Use either the "-f" or the "-include-mirrors" option to run wafliron on SnapMirror® destination volumes. For more information or assistance, contact NetApp technical support.
Syslog Message
%s%s%s: Readonly volumes require additional command options to be checked using wafliron
wafl.iron.readonlyQtrees
Severity
NOTICE
This message occurs during wafliron volume initialization, indicating that volumes with read-only qtrees might not be checked.
Corrective Action
Syslog Message
%s%s%s: Volumes containing readonly qtrees require additional command options to be checked using wafliron
wafl.iron.rebuild.dir.volful
Severity
ERROR
This message occurs while running wafliron, when there might not be enough free space on the volume to rebuild a damaged directory.
Corrective Action
Increase the size of the volume or free space on the aggregate that contains the volume.
Syslog Message
Volume %s might run out of space while wafliron is rebuilding the damaged directory %d. The required space is %d MB.
fileid (INT): Identifying number for the damaged directory.
spaceNeeded (INT): Amount of spaced needed, in megabytes.
wafl.iron.salvaged.rootdir
Severity
INFORMATIONAL
This message occurs when wafliron detects a corrupted rootdir in an index-dir-enabled volume and re-creates it with all valid entries in the rootdir. The old corrupted rootdir has been converted into a regular file and linked to the /lost+found directory.
Corrective Action
Remove the file from the /lost+found directory.
Syslog Message
Rootdir of volume %s has been corrected and contains all valid names. The contents of the old rootdir have been copied to file i#%d.* in the /lost+found directory.
volume (STRING): Name of the volume.
fileid (INT): File ID of the regular file that contains the old rootdir contents as is.
wafl.iron.scan.skipped
Severity
NOTICE
This event occurs when non-specified or read only volumes are not processed during a wafliron run on their containing aggregate.
Corrective Action
(None).
Syslog Message
Aggregate %s, wafliron completed - Read only, offline, old version or non-specified volume(s) %s not checked.
aggr (STRING): The aggr name
vvols (STRING): Flexible volumes not processed
wafl.iron.scan.stats
Severity
INFORMATIONAL
This message prints the wafliron scan details about various data objects: for example, files, directories, blocks.
Corrective Action
(None).
Syslog Message
%llu %s done.
count (LONGINT): Number of data objects scanned so far.
object (STRING): Name of the data object.
wafl.iron.scanning.status
Severity
INFORMATIONAL
This message prints wafliron scanning status.
Corrective Action
(None).
Syslog Message
Scanning (%d%% done).
percentage (INT): Scanning percentage.
wafl.iron.slow
Severity
ERROR
This message occurs when a "wafliron start" or a "wafliron show" command is issued and the aggregate that hosts wafliron status files for the aggregate on which wafliron is running contains only one data disk.
Corrective Action
1.Use the "-status-files-vserver" and "-status-files-volume" parameters of the "aggr wafliron start" command to host status files on a non-root aggregate volume, that has an adequate number of data disks that can accommodate the extra workload. 2.Add more disks to the root aggregate using "aggr add" command.
Syslog Message
Aggregate %s: wafliron performance will be significantly impacted because aggregate %s contains only one data disk. Running wafliron with status files hosted on a non-root aggregate volume that has an adequate number of data disks, or adding more disks to the root aggregate is recommended.
status_vol_aggr_name (STRING): Name of the aggregate containing the volume hosting the wafliron status files.
wafl.iron.start
Severity
INFORMATIONAL
This message occurs when the system starts the wafliron process on a volume.
Corrective Action
(None).
Syslog Message
Starting wafliron on %s %s%s%s%s.
optcommit (STRING): Whether wafliron is running in optional-commit mode. If this mode is used, the decision to commit changes is made by the user after wafliron is complete.
prev_cp (STRING): Whether the prev_cp feature of wafliron is being used and, if so, which consistency point the user chose at the prompt.
backup (STRING): Whether the backup feature of wafliron is being used and, if so, what option {no|yes|force|use} is selected. Only applicable to aggregates.
wafl.iron.unrecoverable
Severity
ALERT
This message occurs when a volume is unrecoverable and cannot be ironed or brought online.
Corrective Action
Syslog Message
Flexible volume %s%s on aggregate %s is unrecoverable.
wafl.iron.upgradeRequired
Severity
NOTICE
This message occurs during volume or aggregate initialization if wafliron is enabled and does not support the volume or aggregate file system version. The message indicates that a volume or aggregate upgrade is required and is being attempted without wafliron checking. A wafliron check of the volume or aggregate might be possible after a successful upgrade.
Corrective Action
(None).
Syslog Message
%s '%s%s%s%s' has not been upgraded. Upgrade will proceed without wafliron. The WAFL version on the %s is '%d'; the current WAFL version is '%d'.
Type (STRING): Type of object (volume or aggregate).
owner (STRING): Owner of the volume or aggregate.
vol (STRING): Name of the volume or aggregate.
volident (STRING): Unique identifier of the volume or aggregate in cases where the volume or aggregate name itself is insufficient.
vol_wafl_version (INT): WAFL® version on the volume or aggregate.
current_wafl_version (INT): Current WAFL version.
wafl.iron.volumes.selected.not.exist
Severity
INFORMATIONAL
This message is used to print on the console that the volumes selected for ironing on the aggregate do not exist in the aggregate.
Corrective Action
(None).
Syslog Message
Some of the volumes selected for ironing do not exist in the aggregate %s.
