wafl.maxdirsize events
Creating your file...
wafl.maxdirsize.boot.notice
- Severity
NOTICE
- Description
This event occurs for each volume that has a maxdirsize greater than the default during boot.
- Corrective Action
Use (privilege:advanced) option "volume modify -volume vol_name -maxdir-size new_value" to set the volume's maxdirsize to the default maxdirsize. However, doing so could impact system performance. If you need to increase the maximum directory size, work with technical support.
- Syslog Message
%s%s%s%s: This volume's maxdirsize (%uKB) is higher than the default (%uKB). There may be a performance penalty when doing operations on large directories.
- Parameters
owner (STRING): The volume owner
vol (STRING): The volume name
app (STRING): Application UUID.
volident (STRING): Unique identifier of the volume when the volume name alone is insufficient.
current_maxdirsize (INT): Default maximum directory size value.
default_maxdirsize (INT): Default maximum directory size value.
