wafl.sidl events
Creating your file...
wafl.sidl.blkincons.recovery
- Severity
NOTICE
- Description
This message occurs when a volume or aggregate with single instance data logging enabled encounters a problem in a metafile required for the functioning of the single instance data logging feature. The system will attempt automatic recovery within the next couple of Consistency Points (CPs). During the period of recovery, write performance could be lower than usual.
- Corrective Action
(None).
- Syslog Message
%s:%s encountered a problem in a metafile (sidl). The system will automatically repair the problem.
- Parameters
object_type (STRING): Identifier for the type of object to which this event applies (aggregate or volume).
object_name (STRING): Name of the object.
fileid (INT): File identifier of the metafile.
l0_blk_cnt (LONGINT): Number of L0 blocks present.
exp_blk_cnt (LONGINT): Number of L0 blocks expected.
cpcount (INT): CP that performs automatic recovery.
wafl.sidl.l0incons.recovery
- Severity
NOTICE
- Description
- Corrective Action
(None).
- Syslog Message
- Parameters
fbn (LONGINT): File block number (fbn) where the problem was encountered.
vbn (LONGINT): Value of the volume block number (vbn) that had a problem.
where (STRING): The module that generated the event (write or refill).
wafl.sidl.space.disable
- Severity
NOTICE
- Description
This message occurs when a volume or aggregate disables the single instance data logging feature because the volume or aggregate is too close to full. During the period when single instance data logging is disabled, write performance could be lower than usual.
- Corrective Action
Decrease the space utilization in the volume or aggregate either by deleting data or by growing the volume or aggregate.
- Syslog Message
%s:%s has disabled the single instance data logging feature. Write performance could be lower than usual.
- Parameters
cpcount (INT): Consistency Point (CP) at which the event is generated.
