wafl.sis events
wafl.sis.clone.autodelete.file
Severity
NOTICE
This message occurs when a file clone is autodeleted
Corrective Action
(None).
Syslog Message
'%s' is sent for auto deletion.
path (STRING): File path.
wafl.sis.clone.autodelete.threshold
Severity
NOTICE
This message occurs when file clone create operation fails because volume crossed autodelete threshold.
Corrective Action
Increase the space available to the volume by either adding disks or by freeing space in the volume to allow the cloning operation to continue.
Syslog Message
File clone creation cannot be completed because volume crossed autodelete threshold.
name (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): Uniquely identifies the volume in cases where the volume name itself is insufficient.
wafl.sis.clone.backup.file.cleanup.failed
Severity
ERROR
This message occurs when clone create gets an error while cleaning up the backup file of the pre-existing clone.
Corrective Action
A backup of the pre-existing clone file is saved at the backup file location. Its cleanup needs manual intervention.
Syslog Message
File clone create for the source %s and clone %s returned error while cleaning up the backup file %s of the pre-existing clone with error: %d. Backup file should be deleted to reclaim space.
src_filename (STRING): Source filename.
clone_filename (STRING): Clone filename.
backup_filename (STRING): Backup filename.
error (INT): Error returned from FlexClone® subsystem.
wafl.sis.clone.backup.file.restore.failed
Severity
ERROR
This message occurs when clone create errors out while restoring the backup file to the pre-existing clone.
Corrective Action
Clone create failed after deleting the pre-existing clone. A backup of the pre-existing clone file is saved at the backup file location. It can be used to recover the pre-existing clone file.
Syslog Message
File clone create for the source %s and clone %s failed while restoring the backup file %s to the pre-existing clone with error: %d. Backup file can be moved to the pre-existing clone location for recovering the clone file.
wafl.sis.clone.create.failed
Severity
INFORMATIONAL
This message occurs when attempts to create a file clone fail.
Corrective Action
(None).
Syslog Message
File clone create of clone file %s (fileid: %d) from source file %s (fileid: %d) in volume %s failed with error:%s at line %d with src_fsid %d, dst_fsid %d, src_snapid %d, dir_fileid %d, type %s, category %s.
dst_fileid (INT): File identifier for destination file.
src_fileid (INT): File identifier for source file.
volname (STRING): Volume name.
error (STRING): Error returned from the FlexClone® subsystem.
line_number (INT): Line number where the error has occurred.
src_fsid (INT): File system identifier of source volume.
dst_fsid (INT): File system identifier of destination volume.
snapid (INT): Snapshot copy identifier.
dir_fileid (INT): File identifier for the directory.
type (STRING): Type of Cloning.
category (STRING): Clone create requestor information.
wafl.sis.clone.unlock.snapshot
Severity
NOTICE
This event is issued when the volume options are set such that the autodelete destroy policy is allowed to destroy backing snapshots for sis clones. The snapshot autodelete destroy policy is used as a last resort to recover space in a thin provisioned aggregate. The disruptive effect of destroying sis clone backing snapshots should be understood when setting this policy.
Corrective Action
(None).
Syslog Message
Unlocked sis clone backing snapshot in volume %s. Clone files based on snapshot (%d, %d) might become inconsistent.
name (STRING): The volume name
snapid (INT): Snapshot(tm) copy identifier.
cp_cnt (INT): The CP(Consistency Point) count. The (snapid, cp_count) pair uniquely identifies a Snapshot copy.
