wafl.snaprestore events
Creating your file...
wafl.snaprestore.badVersion
- Severity
ERROR
- Description
This message occurs during a Snapshot(tm) copy restore operation, when the system cannot recognize the version of Data ONTAP® from the Snapshot copy it is reverting to. The Snapshot copy is corrupt and cannot be used.
- Corrective Action
Cancel the Snapshot copy restore operation, if necessary, and restore to a different Snapshot copy.
- Syslog Message
Snapshot copy is from an unrecognizable version of Data ONTAP. (vol='%s', volident='%s')
- Parameters
vol (STRING): Volume name.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
wafl.snaprestore.cancel.invalid
- Severity
NOTICE
- Description
This message occurs during volume initialization when the system cancels a SnapRestore® process due to an invalid Snapshot™ copy.
- Corrective Action
Select a different Snapshot copy and reattempt the restore operation.
- Syslog Message
Snapshot is invalid; canceling pending "vol snaprestore" for %s %s%s%s%s.
- Parameters
type (STRING): Type of object (volume/aggregate).
owner (STRING): Owner of the volume.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Unique identifier of the volume when the volume name by itself is insufficient.
wafl.snaprestore.cancel.prevcp
- Severity
INFORMATIONAL
- Description
This message occurs during volume initialization from a previous consistency point (CP) when the system cancels a SnapRestore® process. This happens when booting to a previous CP.
- Corrective Action
Retry the SnapRestore operation after the system completes bootup.
- Syslog Message
Canceling pending "vol snaprestore" for %s %s%s%s%s.
- Parameters
wafl.snaprestore.defer.prevcp
- Severity
INFORMATIONAL
- Description
This message occurs during a read-only boot to the previous consistency point (CP). In this case, the pending SnapRestore® process is deferred.
- Corrective Action
(None).
- Syslog Message
Readonly mode; deferring "vol snaprestore" for %s %s%s%s%s.
- Parameters
wafl.snaprestore.revert
- Severity
INFORMATIONAL
- Description
This message occurs during volume initialization when the system reverts to a previous Snapshot™ copy.
- Corrective Action
(None).
- Syslog Message
Reverting %s %s%s%s%s to a previous Snapshot copy with snapid %d.
- Parameters
snapId (INT): Identifier for the Snapshot copy.
wafl.snaprestore.stale
- Severity
ERROR
- Description
This message occurs during a Snapshot(tm) copy restore operation, when the system determines that the Snapshot copy it is restoring from is stale. The Snapshot copy is corrupt and cannot be used.
- Corrective Action
Cancel the Snapshot copy restore operation, if necessary, and restore from a different Snapshot copy.
- Syslog Message
Snapshot copy is stale. (vol='%s', volident='%s')
- Parameters
