wafl.spcmgmt events
Creating your file...
wafl.spcmgmt.policyConflict
- Severity
NOTICE
- Description
This message occurs when a space management strategy or an autosize grow threshold for a volume is being configured and the autogrow or autodelete thresholds conflict with the space-mgmt-try-first policy. The conflict can arise when the autogrow threshold is less than the autodelete threshold and the space-mgmt-try-first policy is configured for "snap_delete". The conflict can also arise when the autogrow threshold is more than the autodelete threshold and space-mgmt-try-first is configured for "volume_grow".
- Corrective Action
Consider changing either the space-mgmt-try-first policy with the command "volume modify -volume <volume_name> -space-mgmt-try-first <option>" or the autogrow threshold with the command "volume modify -volume <vol_name> -autosize-grow-threshold-percent <value>", and keep them in sync.
- Syslog Message
While configuring "%s" for volume "%s", space_mgmt_try_first policy ("%s") is conflicted with the autogrow threshold (%d%%) and autodelete threshold (%d%%).
- Parameters
command (STRING): Command being executed.
volume_name (STRING): Name of the volume.
space_mgmt_try_first (STRING): space-mgmt-try-first policy for volume_grow or snap_delete.
grow_threshold (INT): Used-space threshold, as a percentage, for the automatic growth of the volume.
delete_threshold (INT): Used-space threshold, as a percentage, for the auto-deletion of Snapshot copies.
