The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
bcomd.fcnvmelifmovefail events
Creating your file...
Your file is ready
bcomd.fcNvmeLifMoveFail
- Severity
EMERGENCY
- Description
This message occurs when a LIF move failed and the recovery action to restore the LIF has also failed. Namespaces are no longer accessible through this LIF. The LIF must be recovered manually.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
Moving FC-NVMe LIF %s of vserver %s from %s:%s to %s:%s failed. Manual recovery required.
- Parameters
lif_name (STRING): LIF name.
vserver_uuid (STRING): Vserver Uuid.
src_node (STRING): LIF was moving from this node.
src_port (STRING): LIF was moving from this port.
dest_node (STRING): LIF was moving to this node.
dest_port (STRING): LIF was moving to this port.
