The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
callhome.sm events
Creating your file...
Your file is ready
callhome.sm.vsdr.break.fail
- Severity
ERROR
- Description
This message occurs when a break operation on a SnapMirror® relationship that is a part of VserverDR fails. If your system is configured to do so, it generates and transmits an AutoSupport (or "call home") message to NetApp technical support and to the configured destinations. Successful delivery of an AutoSupport message significantly improves problem determination and resolution.
- Corrective Action
Contact NetApp technical support for additional information.
- Syslog Message
Call home for SNAPMIRROR BREAK FAILURE.
- Parameters
subject (STRING): AutoSupport subject or title for this event.
SourceVserver (STRING): Source Vserver of the SnapMirror relationship.
DestVserver (STRING): Destination Vserver of the SnapMirror relationship.
