clam.failover events
Creating your file...
Your file is ready
clam.failover.event
- Severity
INFORMATIONAL
- Description
This message occurs when the Kernel Cluster Services (KCS) Connectivity, Liveliness, Availability Monitor (CLAM) receives a failover event from high-availability(HA) subsystem.
- Corrective Action
(None).
- Syslog Message
CLAM on node (id=%llu) received an HA failover event for partner (ID=%llu) indicating that %s.
- Parameters
localnodeid (LONGINT): Node ID of the local node.
partnernodeid (LONGINT): Node ID of the partner node.
event_description (STRING): Description of the event that CLAM received from the HA subsystem.
