The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
config.habadbank2 events
Creating your file...
Your file is ready
config.HABadBank2
- Severity
ALERT
- Description
This message occurs when a local host adapter is connected to a different switch bank (on ports 0-7) than other adapters on this controller, which are connected to ports 8-15. This is an illegal configuration.
- Corrective Action
Connect all of the adapters of this controller to the same bank of switch ports.
- Syslog Message
Other local host adapters are connected to Switch bank 2 (ports 8-15). Host adapter %s is connected to Switch bank 1 (ports 0-7). This is an illegal configuration.
- Parameters
ha (STRING): Name of the host adapter.
