The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
cpeer.passphrase events
Creating your file...
Your file is ready
cpeer.passphrase.expired
- Severity
NOTICE
- Description
This message occurs when the cluster peer offer for anonymous cluster with system-generated passphrase expired and deleted.
- Corrective Action
If required, use the "cluster peer create" command with "generate-passphrase" option to generate the additional cluster peer offers.
- Syslog Message
The cluster peer offer with system-generated passphrase (%s) expired and deleted.
- Parameters
passphase_details (STRING): Cluster peer passphrase details.
