crypto.ssal events
crypto.ssal.failed
- Severity
ALERT
 - Description
This message occurs when a Secure Storage Access Layer(SSAL) operation fails. This might cause import of the onboard key hierarchy to fail and might result in a temporary loss of access to any data secured using the SSAL.
 - Corrective Action
(Call support).
 - Syslog Message
SSAL operation failed: %s. %s
 - Parameters
failure_msg (STRING): Message describing which operation failed.
additional_msg (STRING): Additional information regarding the failure.
crypto.ssal.tpm.clear
- Severity
NOTICE
 - Description
This message occurs when a Trusted Platform Module(TPM) clear operation is performed successfully. A TPM clear operation can happen while reverting to a previous release or when the "security tpm clear" command was executed. A TPM clear operation clears out the TPM and resets it with a new seed for the TPM's storage hierarchy.
 - Corrective Action
(None).
 - Syslog Message
A TPM clear operation has been completed successfully.
 - Parameters
(None).
crypto.ssal.tpm.reset
- Severity
NOTICE
 - Description
This message occurs when a Trusted Platform Module(TPM) reset operation is performed successfully. A TPM reset operation can happen when the node boots up for the first time or when the "security tpm reset" command was executed. A TPM reset operation clears out the TPM and resets it with a new seed for the TPM's storage hierarchy. The TPM then generates a new primary key under the same hierarchy and makes it persistent.
 - Corrective Action
(None).
 - Syslog Message
A TPM reset operation has been completed successfully.
 - Parameters
(None).
