dbs.discon events
dbs.discon EMS events occur when the Distributed Block Store (DBS) is unable to access a snapmirror endpoint on the network.
dbs.discon.snapmirror.end
- Severity
ERROR
- Description
This message occurs when the Distributed Block Store (DBS) is unable to access snapmirror endpoint on the network. The DBS is responsible for managing the data that backs the FlexVols®.
- Corrective Action
Check network connectivity between the cluster and the remote snapmirror endpoint. Check the 1G management network.
- Syslog Message
The Distributed Block Store is unable to access the snapmirror endpoint from cluster. The cluster fault type is %s and fault id is %u.
- Parameters
cfType (STRING): DBS cluster fault type of the associated object.
cfID (INT): DBS cluster fault ID number associated with the fault.
cfStatus (INT): Current status of the cluster fault. 1 = New (just reported), 2 = Existing (updated), 3 = Resolved (closed).
cfDetails (STRING): Description of the cluster fault, including context details.
cfExtSrc (STRING): DBS cluster fault externalSource label created by the CreateClusterFault API command and attached to the fault for testing purposes.
