ONTAP EMS reference
dbs.service events
dbs.service EMS events occur when ONTAP encounters issues associated with Distributed Block Store (DBS) service availability, such as a service failing to start or not running.
dbs.service
Severity
NOTICE
This message occurs when a Distributed Block Store (DBS) service event occurs, such as inability to start the FireStorm service.
Corrective Action
(None).
Syslog Message
A DBS service event %s of type %s occurred for Service ID %u on node %u/%s. Drive ID = %u/%s. Event ID = %u.
evtMessage (STRING): Description of the DBS event, including context details.
evtType (STRING): Type of the original DBS event.
serviceID (INT): Service ID that identifies the associated DBS service. It is 0 if there is no associated service.
nodeID (INT): Node ID number of the associated node. It is 0 if there is no associated node.
nodeUuid (STRING): Generated Universal Unique Identifier (UUID) of the associated node. It displays zeroes if there is no associated node.
driveID (INT): Drive ID number of the associated drive. It is 0 if there is no associated drive.
driveUuid (STRING): Generated UUID of the associated drive. It displays zeroes if there is no associated drive.
evtID (INT): DBS event ID number.
evtDetails (STRING): Specific details of the DBS event. It displays as a string, in JSON format, or is empty.
dbs.service.not.running
Severity
ALERT
This message occurs when Distributed Block Store (DBS) detects a service is not running.
Corrective Action
Verify that the service is started within 10 minutes.
Syslog Message
DBS has detected a service is not running. Cluster fault service ID %u, node %u, node UUID %s, type %s, fault ID %u, status %u. %s
serviceID (INT): Service ID that identifies the associated cluster service.
nodeUuid (STRING): Node UUID string of the associated node.
cfType (STRING): DBS cluster fault type of the associated object.
cfID (INT): DBS cluster fault ID number associated with the fault.
cfStatus (INT): Current status of the cluster fault. 1 = New (just reported), 2 = Existing (updated), 3 = Resolved (closed).
cfDetails (STRING): Description of the cluster fault, including context details.
cfExtSrc (STRING): DBS cluster fault externalSource label created by the CreateClusterFault API command and attached to the fault for testing purposes.
