disk.lipstormdetect events
Creating your file...
Your file is ready
disk.lipStormDetect
- Severity
NOTICE
- Description
This message occurs when a Fibre Channel disk detects a large number of Loop Initialization Procedure requests (a LIP storm) and has reset itself.
- Corrective Action
None required. If this happens a second time, the disk will be failed.
- Syslog Message
shm: disk %s reports a LIP storm reset. %s. Error %x/%x/%x/%x.
- Parameters
diskName (STRING): Name of the disk (host adapter, loop ID).
disk_info (STRING): Static description of events on the disk.
sense_key (INT): Actual sense key.
sense_code (INT): Actual sense code.
qualifier (INT): Actual sense code qualifier.
fru_failed (INT): Actual FRU code.
