ONTAP EMS reference
disk.min events
disk.min.OS.error
Severity
ERROR
This message occurs when a disk is detected that is not supported in this version of Data ONTAP®.
Corrective Action
Remove the disk and replace it with a disk that is supported, or upgrade the kernel to the required version.
Syslog Message
%s is not supported because it requires a minimum kernel version of %s. Current version is %s.
disk_information (STRING): Disk information.
min_OS_version (STRING): Disk's minimum supported Data ONTAP version.
cur_OS_version (STRING): Current version of the Data ONTAP.
