disk.toomanypartitioneddisks events
Creating your file...
Your file is ready
disk.tooManyPartitionedDisks
- Severity
ALERT
- Description
This message occurs when Data ONTAP® finds more partitioned disks present on a platform than the platform supports. The system ignores any partitioned disks above the limit, and they will be unusable.
- Corrective Action
Too many partitioned disks have been installed. Reconfigure the system to the maximum number of partitioned disks supported.
- Syslog Message
Ignoring partitioned disk %s because the maximum limit of %d partitioned disks supported on this system has been reached.
- Parameters
diskName (STRING): Name of the disk.
maxPartitionedDisks (INT): Maximum number of partitioned disks supported on this platform.
