The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
dump.xfercomplete events
Creating your file...
Your file is ready
dump.xfercomplete.inconsistent_data
- Severity
ERROR
- Description
This message occurs when the dump engine completes data backup with disk errors in user files.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
Dump of source path (%s): One or more files in the backup encountered disk errors. Refer to /etc/log/backup for a list of files that encountered disk errors.
- Parameters
src_path (STRING): Source path being backed up.
