esh.bypass events
esh.bypass.err.disk
Severity
ERROR
This message occurs when there is a disk bypass event. It indicates that a disk is bypassed by the embedded switched hub (ESH) due to one of the following reasons: Manually bypassed; Transmitter fault; LIP F8; Data timeout; Receiver loss of signal; Comma loss of signal; Loop test before insert failure; Redundant port configuration; Exceeded stall threshold; Exceeded word error threshold; Exceeded CRC error threshold; or Exceeded clock delta error threshold.
Corrective Action
Replace the bypassed disk.
Syslog Message
Disk %s%son channels %s disk shelf ID %d %s%s%s.
diskID (STRING): Disk that is being bypassed.
disk_data (STRING): disk data includes vendor name, model, firmware revision and the serial number of the disabled disk. If won't bw able to access the disk then this field will be blank.
channels (STRING): Channels that have the error if local, PARTNER for high-availability partner, UNUSED if unconnected.
shelfID (INT): Disk shelf ID (1-7) of the disk shelf reporting the error.
element (STRING): ESH module designator (A is the upper module, B is the lower module).
bay (STRING): Bay in which the disk is installed.
reason (STRING): Reason the disk was bypassed.
esh.bypass.host.port
Severity
ALERT
This message occurs when there is a host port bypass event. It indicates that a host port is bypassed by the embedded switched hub (ESH) due to one of the following reasons: Manually bypassed; Transmitter fault; LIP F8; Data timeout; Receiver loss of signal; Comma loss of signal; Loop test before insert failure; Redundant port configuration; Exceeded stall threshold; Exceeded word error threshold; Exceeded CRC error threshold; or Exceeded clock delta error threshold.
Corrective Action
Replace the disk shelf module to which the concerned host port belongs.
Syslog Message
%s on channels %s disk shelf ID %d %s%s.
portID (STRING): Host port that is being bypassed.
reason (STRING): Reason the host port was bypassed.
