fcadmin.bridge events
fcadmin.bridge.prog.disk
Severity
INFORMATIONAL
This event reports the WWN written to a device.
Corrective Action
(None).
Syslog Message
Programming Disk %s LUN=%d on Path=0x%0x with WWN %02x:%02x:%02x:%02x:%02x:%02x:%02x:%02x.
diskName (STRING): Name of the disk.
LUNid (INT): Logical Unit Number identifier.
pathAddress (INTHEX): Device address.
WWNbyte0 (INTHEX): 0th byte of World Wide Name.
WWNbyte1 (INTHEX): 1st byte of World Wide Name.
WWNbyte2 (INTHEX): 2nd byte of World Wide Name.
WWNbyte3 (INTHEX): 3rd byte of World Wide Name.
WWNbyte4 (INTHEX): 4th byte of World Wide Name.
WWNbyte5 (INTHEX): 5th byte of World Wide Name.
WWNbyte6 (INTHEX): 6th byte of World Wide Name.
WWNbyte7 (INTHEX): 7th byte of World Wide Name.
fcadmin.bridge.prog.done
Severity
INFORMATIONAL
This message indicates that WWN programming has been successfully completed on a disk.
Corrective Action
(None).
Syslog Message
Disk %s LUN=%d on path=0x%0x successfully programmed. Reboot the drive to see the updated WWN.
fcadmin.bridge.prog.fault
Severity
ERROR
This message indicates that the attempt to write the WWN to the disk has failed.
Corrective Action
Retry the command after sometime, error might be transient.
Syslog Message
Error programming disk %s LUN=%d on path=0x%0x. Error status=0x%0x.
commandStatus (INTHEX): Returned SCSI error code.
fcadmin.bridge.progWWN
Severity
INFORMATIONAL
This message reports the statistics of the operation to write the World Wide Name (WWN) to the drives.
Corrective Action
(None).
Syslog Message
Total LUNs/drives reported = %d. Total LUNs/drives programmed = %d.
reportedLUNs (INT): Total number of LUN instances reported for entire session.
programmedLUNs (INT): Total number of LUN instances programmed for entire session.
fcadmin.bridge.retrieve.fail
Severity
ERROR
This event is generated when the drive is not qualified for DDB (Disk Drive Behavior) update while programming the WWNs.
Corrective Action
(None).
Syslog Message
Error retrieving DDB data for disk=%s on path=0x%0x. Drives on the current path could not be programmed with WWN.
fcadmin.bridge.rprt.fault
Severity
ERROR
This message is generated when the Report LUNs response completed with some error.
Corrective Action
Syslog Message
Error reported for Report LUN command on disk %s on path 0x%0x, error=0x%0x.
fcadmin.bridge.rprtcmd.fail
Severity
ERROR
This event is generated when insufficient SCSI command blocks are available for Report LUN command.
Corrective Action
Retry the command after sometime. As command blocks may have become available.
Syslog Message
Memory allocation failed for Report LUN command. No LUN instances are programmed.
(None).
fcadmin.bridge.rprtdata.fail
Severity
ERROR
Corrective Action
Syslog Message
Memory allocation failed for Report LUN data command, bytes Requested=%d Disk %s on Path=0x%0x.
requestedMemory (INT): Requested memory for Report LUN data command.
deviceAddress (INTHEX): Device address.
fcadmin.bridge.WWN.prog.stat
Severity
INFORMATIONAL
This event is generated when the programming of the WWNs into the reported LUNs is complete. An error in programming is indicated when the number of reported LUNs is different from the number programmed.
Corrective Action
(None).
Syslog Message
WWN update completed on disk %s path 0x%0x, total %d LUNS reported, total %d LUNS programmed.
LUNsReported (INT): Number of LUNs reported.
LUNsProgrammed (INT): Number of LUNs programmed.
