ONTAP EMS reference
fci.config events
fci.config.autoReboot
Severity
NOTICE
This message occurs when the system reboots automatically to enable correct adapter operation after changing the state of a reconfigurable adapter.
Corrective Action
No user action is required. The system is rebooting to enable the new adapter configuration.
Syslog Message
Rebooting for Fibre Channel adapter %s to become available.
adapters (STRING): Affected adapters.
fci.config.error
Severity
ERROR
This message occurs when there is an error during the Fibre Channel adapter auto-reconfiguration process. The specified adapters will be unavailable until the problem is fixed.
Corrective Action
Contact NetApp technical support.
Syslog Message
Auto-reconfiguration for Fibre channel %s adapter(s) %s has failed.
type (STRING): Adapter type.
adapters (STRING): Affected adapter(s).
fci.config.missing
Severity
ERROR
This message occurs when the system cannot find Fibre Channel adapter configuration stored on disk, but the adapter is configured in the boot environment. The boot environment information will be used, but you should update the on-disk configuration to be consistent and to prevent the adapter from getting into an unexpected state if the boot environment settings are lost.
Corrective Action
Use the 'fcadmin config' command to reapply the on-disk configuration to match the setting in the boot environment. If the on-disk configuration is not saved and the boot environment is lost, recovery of this adapter's port personality is not possible. No action is taken automatically to correct the problem.
Syslog Message
Fibre Channel adapter %s is configured in the boot environment but the on-disk configuration information is missing.
adapter (STRING): Name of the affected Fibre Channel adapter.
fci.config.needsReboot
Severity
ERROR
This message occurs when the state of a reconfigurable adapter is changed, but the system must be rebooted to place the adapter into service.
Corrective Action
Reboot the system to enable the new adapter configuration.
Syslog Message
Reboot the system for Fibre channel %s adapter %s to become available.
fci.config.offline
Severity
NOTICE
This message occurs when a configurable Fibre Channel adapter cannot be brought online because the configured adapter type needs to be changed.
Corrective Action
Use the 'fcadmin config' utility to change the adapter configuration state and/or reboot the system to allow the PENDING adapter state change to take effect before bringing the adapter online.
Syslog Message
Fibre Channel adapter %s is offline because it is in the %s state.
adapter (STRING): Name of the associated Fibre Channel adapter.
state (STRING): Configured adapter state.
fci.config.state
Severity
NOTICE
This message occurs when the state of a configurable Fibre Channel adapter changes.
Corrective Action
(None).
Syslog Message
Fibre Channel %s adapter %s is in the %s state.
type (STRING): Current adapter type.
