fli.lun events
fli.lun.import.checkpoint
- Severity
ERROR
 - Description
This message occurs when a checkpoint record delete fails. Checkpoint is metadata information stored with the NetApp LUN attribute stream for tracking import progress. An attempt is made to delete this metadata during import stop or delete operations.
 - Corrective Action
This record can remain in the LUN attribute stream without any harm. It could occupy ~100-200 bytes of space in the LUN attribute stream. If that is an issue, a support personnel could be contacted to delete this record.
 - Syslog Message
Import checkpoint record could not be deleted for LUN %s - Reason:%s
 - Parameters
LUNSerialNumber (STRING): Serial number of the LUN.
FailureReason (STRING): Internal error reason.
fli.lun.import.complete
- Severity
INFORMATIONAL
 - Description
This message occurs when a foreign LUN import is complete.
 - Corrective Action
(None).
 - Syslog Message
Import of foreign LUN %s of size %lld bytes from array model %s belonging to vendor %s is successfully completed. Destination NetApp LUN is %s.
 - Parameters
DiskSerialNumber (STRING): Foreign disk serial number.
Size (LONGINT): Size of the foreign LUN.
ForeignArrayModelID (STRING): Foreign array model ID.
ForeignArrayVendor (STRING): Foreign array vendor name.
fli.lun.import.failed
- Severity
ERROR
 - Description
This message occurs when a foreign LUN import goes into failed state. 1. Data could not be read from the source(foreign LUN). 2. Data could not be written to the destination(NetApp LUN). 3. This is an Internal/metadata related error.
 - Corrective Action
Verify the connectivity to the foreign disk. 2. Verify that the destination volume is online and has enough space by using "volume show" command. 3. Run the "lun import pause" command followed by a "lun import resume" command. In certain cases, the import might need to be restarted ( Use "lun import stop" command followed by "lun import start" command). The ultimate recovery is to delete this relationship (with -force option) and create it again.
 - Syslog Message
Import of foreign LUN %s to LUN %s failed - Reason:%s
 - Parameters
fli.lun.import.inconsistent
- Severity
ERROR
 - Description
This message occurs when the import inconsistent flag cannot be unset. The import inconsistent flag is a system attribute for the NetApp LUN that is set during import progress, to indicate inconsistent data in the destination LUN. This is to discourage restore operations on LUN Snapshot(tm) copies created during import. A best effort is done to unset this flag after the import is complete, and also during import stop and delete operations. It is safe to perform restore operations if data in the destination LUN is known to be successfully verified.
 - Corrective Action
(None).
 - Syslog Message
Import inconsistent flag could not be unset for LUN %s - Reason:%s
 - Parameters
fli.lun.verify.complete
- Severity
INFORMATIONAL
 - Description
This message occurs when a foreign LUN import verify is complete.
 - Corrective Action
(None).
 - Syslog Message
Import verify of foreign LUN %s of size %lld bytes from array model %s belonging to vendor %s with NetApp LUN %s is successfully completed.
 - Parameters
ForeignArrayVendor (STRING): Foreign array name.
fli.lun.verify.failed
- Severity
ERROR
 - Description
This message occurs when a foreign LUN import verify fails. 1. Data could not be read from the source(foreign LUN). 2. Data could not be written to the destination(NetApp LUN). 3. There was a data mismatch during the verify operation. 4. There was an internal error.
 - Corrective Action
For a data mismatch, start the import operation again. 2. Verify the connectivity to the foreign disk. 3. Verify that destination volume is in a healthy state. In certain cases, the verify operation might need to be restarted (Use "lun import verify stop" command followed by "lun import verify start" command). The ultimate recovery is to delete this relationship (with -force option) and create it again.
 - Syslog Message
Import verify of foreign LUN %s and NetApp LUN %s failed - Reason:%s
 - Parameters
