ONTAP EMS reference
hashd.maxstore events
hashd.maxstore EMS events occur when the size of hashes in the hash store is greater than the maximum size configured.
hashd.maxstore.oversize
Severity
NOTICE
This message occurs when the size of hashes in the hash store is greater than the maximum size configured.
Corrective Action
If the hash files are not being retained for a long enough duration, consider resizing the maximum size of the hash store by issuing the 'vserver cifs branchcache modify -hash-store-max-size' command.
Syslog Message
Size of the hashes in the hash store exceeded maximum size configured for Vserver %s.%s
vserver_name (STRING): Name of the Vserver where the problem is occuring.
oldestKept_timestamp (STRING): Timestamp of the oldest kept hash file.
