ONTAP EMS reference
lmgr.mismatch events
lmgr.mismatch.file.objects
Severity
NOTICE
This message occurs when the current file object of a lock does not match the file object found through the file handle. This might be caused by a SnapMirror® promote operation where the Master Data Set ID (MSID) is remapped.
Corrective Action
None.
Syslog Message
(None).
volume (STRING): Name of the volume, based on the file handle.
lockid (STRING): Lock Universal Unique Identifier (UUID) of the sharelock.
caller (STRING): WAFL® spinnp operation that encountered this event.
