ONTAP EMS reference
monitor.ioexpansiontemperature events
monitor.ioexpansionTemperature.cool
Severity
EMERGENCY
This warning message occurs when the I/O expansion module is too cold.
Corrective Action
The system cannot function in an environment that is too cold; find ways to warm the system.
Syslog Message
I/O expansion module is too cold: %s
describe_toocool (STRING): Reading and state of the temperature sensors on the I/O expansion module.
monitor.ioexpansionTemperature.ok
Severity
NOTICE
This message occurs when the temperature of the I/O expansion module is normal. It can occur for the following two cases: 1) LOG_NOTICE to show that a bad condition has reverted to normal. 2) LOG_INFO for hourly to indicate that the temperature is OK.
Corrective Action
No corrective action is needed.
Syslog Message
Temperature of the I/O expansion module is OK.
(None).
monitor.ioexpansionTemperature.warm
Deprecated
Deprecated as of version 9.2.0 to address the EMS ID length violation.
Severity
ALERT
This warning message occurs when the I/O expansion module is too warm.
Corrective Action
Evaluate the environment in which the system is functioning: are air conditioning units needed or is the current air conditioning not functioning properly?
Syslog Message
I/O expansion module is too warm: %s
describe_toowarm (STRING): Reading and state of the temperature sensors on the I/O expansion module.
