The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
moveagent.phase events
Creating your file...
Your file is ready
moveagent.phase.queryerr
- Severity
NOTICE
- Description
This message occurs when an active volume move operation cannot access the volume move phase information.
- Corrective Action
Monitor the currently running volume move job using the 'volume move show' clustered Data ONTAP command. If the volume move completes successfully, no further action is necessary. If the volume move fails, you can retry the volume move or contact NetApp technical support for assistance.
- Syslog Message
Cannot determine the vol move phase information for volume with DSID %llu.
- Parameters
volume_dsid (LONGINT): Destination volume data set identifier(DSID).
