The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
mpt.phydisk events
Creating your file...
Your file is ready
mpt.phydisk.path.failed
- Severity
ERROR
- Description
This message occurs when the system cannot allocate a physical disk path in the message processing technology (MPT) adapter driver.
- Corrective Action
Check whether the device is connected correctly.
- Syslog Message
%s : Unable to allocate physical disk path.
- Parameters
mpt (STRING): MPT device name on the path that failed.
