ndo.cr events
ndo.cr EMS events occur when ONTAP encounters issues associated with controller replacement operations.
ndo.cr.canceled
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation is canceled by the operator.
- Corrective Action
(None).
- Syslog Message
Controller replacement operation on node "%s" is canceled by the operator.
- Parameters
nodeName (STRING): Name of the node that was being replaced when the operation was canceled.
ndo.cr.completed
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation has been completed successfully in the HA group.
- Corrective Action
(None).
- Syslog Message
Controller replacement operation completed. New node "%s" (model: %s), HA partner node "%s" (model: %s)
- Parameters
newNodeName (STRING): Node name of the first new controller.
newModelName (STRING): Model name of the first new controller.
haNodeName (STRING): Node name of the new HA partner controller.
haModelName (STRING): Model name of the new HA partner controller.
ndo.cr.completed.firstNode
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation has been completed on the first node of the HA group.
- Corrective Action
(None).
- Syslog Message
Controller replacement operation completed on the first controller of the HA group. New node: %s (model: %s).
- Parameters
nodeName (STRING): Node name of the new controller.
modelName (STRING): Model name of the new controller.
ndo.cr.nso.canceled
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation using negotiated switchover (NSO) in a MetroCluster FC configuration has been canceled.
- Corrective Action
(None).
- Syslog Message
NSO-based controller replacement operation was canceled from node: %s. Remote cluster node: %s, remote cluster HA partner node: %s.
- Parameters
initiatingClusterNodeName (STRING): Name of the node from where controller replacement operation was canceled.
targetClusterNodeName (STRING): Node name of the controller that will be replaced.
targetClusterHApartnerNodeName (STRING): Node name of the HA partner controller that will be replaced.
ndo.cr.nso.completed
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation using negotiated switchover (NSO) in a MetroCluster FC configuration has completed.
- Corrective Action
(None).
- Syslog Message
NSO-based controller replacement operation completed. Initiating cluster node: %s, remote cluster node: %s (model: %s), remote cluster HA partner node: %s (model: %s).
- Parameters
initiatingClusterNodeName (STRING): Node name of the controller that has initiated the upgrade.
newTargetClusterNodeName (STRING): Node name of the new controller.
newTargetClusterModelName (STRING): Model name of the new controller.
newTargetClusterHApartnerNodeName (STRING): Node name of the new HA partner controller.
newTargetClusterHApartnerModelName (STRING): Model name of the new HA partner controller.
ndo.cr.nso.mccip.canceled
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation using negotiated switchover (NSO) in a MetroCluster IP configuration has been canceled.
- Corrective Action
(None).
- Syslog Message
An NSO-based controller replacement operation was canceled in a MetroCluster IP configuration from node "%s". The remote cluster node is "%s", and the remote cluster HA partner node is "%s".
- Parameters
initiatingClusterNodeName (STRING): Name of the node where the controller replacement operation was canceled.
targetClusterNodeName (STRING): Node name of the controller that was to be replaced.
targetClusterHApartnerNodeName (STRING): Node name of the HA partner controller that was to be replaced.
ndo.cr.nso.mccip.completed
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation using negotiated switchover (NSO) in a MetroCluster IP configuration has completed.
- Corrective Action
(None).
- Syslog Message
An NSO-based controller replacement operation completed in a MetroCluster IP configuration. The initiating cluster node is "%s", remote cluster node is "%s" (model "%s"), and the remote cluster HA partner node is "%s" (model "%s").
- Parameters
initiatingClusterNodeName (STRING): Node name of the controller that initiated the controller replacement operation.
ndo.cr.nso.mccip.paused
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation using negotiated switchover (NSO) in a MetroCluster IP configuration has been paused.
- Corrective Action
Use the "system controller replace show-details" command to check the status of the operation. Then, use the "system controller replace resume" command to resume the replacement operation.
- Syslog Message
An NSO-based controller replacement operation was paused in a MetroCluster IP configuration from node "%s". The remote cluster node is "%s", and the remote cluster HA partner node is "%s".
- Parameters
initiatingClusterNodeName (STRING): Name of the node from where the controller replacement operation was paused.
targetClusterNodeName (STRING): Node name of the controller that is being replaced.
targetClusterHApartnerNodeName (STRING): Node name of the HA partner controller that is being replaced.
ndo.cr.nso.mccip.paused.error
- Severity
ERROR
- Description
This message occurs when a controller replacement operation using negotiated switchover (NSO) in a MetroCluster IP configuration was paused due to an error.
- Corrective Action
Use the "system controller replace show-details" command to check the status of the operation. Resolve the error. Then, use the "system controller replace resume" command to resume the replacement operation.
- Syslog Message
An NSO-based controller replacement operation has been paused in a MetroCluster IP configuration on node "%s" during a task "%s" due to the following error: %s.
- Parameters
nodeName (STRING): Name of the node where the controller replacement operation was paused due to an error.
taskName (STRING): Name of the task.
taskReport (STRING): Detailed error report.
ndo.cr.nso.mccip.paused.userInput
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation using negotiated switchover (NSO) in a MetroCluster IP configuration has been paused for operator intervention.
- Corrective Action
Use the "system controller replace show-details" command to check the status of the operation. Collect the requested information or perform the steps as mentioned in the "system controller replace show-details" command output. Then, use the "system controller replace resume" command to resume the replacement operation.
- Syslog Message
An NSO-based controller replacement operation from initiating node "%s" has been paused in a MetroCluster IP configuration. The remote cluster node "%s" and remote cluster HA partner node "%s" have been paused for operator interventio while performing a "%s" task during the "%s" phase.
- Parameters
initiatingClusterNodeName (STRING): Name of the node where the controller replacement operation was initiated.
taskName (STRING): Name of the task where the controller replacement operation has been paused for operator intervention.
phaseInfo (STRING): Name of the phase where the controller replacement operation has been paused for operator intervention.
ndo.cr.nso.mccip.resumed
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation using negotiated switchover (NSO) in a MetroCluster IP configuration has been resumed.
- Corrective Action
(None).
- Syslog Message
An NSO-based controller replacement operation has been resumed in a MetroCluster IP configuration from node "%s". The remote cluster node is "%s", and the remote cluster HA partner node is "%s".
- Parameters
initiatingClusterNodeName (STRING): Name of the node from where the controller replacement operation has been resumed.
ndo.cr.nso.mccip.started
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation using negotiated switchover (NSO) in a MetroCluster IP configuration has been started.
- Corrective Action
(None).
- Syslog Message
An NSO-based controller replacement operation has been started in a MetroCluster IP configuration. The local cluster node is "%s", the remote cluster node is "%s" (model "%s"), and the remote cluster HA partner node is "%s" (model "%s").
- Parameters
targetClusterModelName (STRING): Model name of the controller that will be replaced.
targetClusterHApartnerModelName (STRING): Model name of the HA partner controller that will be replaced.
ndo.cr.nso.paused
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation using negotiated switchover (NSO) in a MetroCluster FC configuration has been paused.
- Corrective Action
- Syslog Message
NSO-based controller replacement operation was paused from node: %s. Remote cluster node: %s, remote cluster HA partner node: %s.
- Parameters
ndo.cr.nso.paused.error
- Severity
ERROR
- Description
This message occurs when a controller replacement operation using negotiated switchover (NSO) in a MetroCluster FC configuration has been paused due to an error.
- Corrective Action
- Syslog Message
NSO-based controller replacement operation has been paused on node "%s" during %s task due to an error: %s.
- Parameters
nodeName (STRING): Name of the node where the controller replacement operation has been paused due to an error.
ndo.cr.nso.paused.userInput
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation using negotiated switchover (NSO) in a MetroCluster FC configuration has been paused for operator intervention.
- Corrective Action
Use the "system controller replace show-details" command to check the status of the operation. Collect the requested information or perform the steps as mentioned in the "system controller replace show-details" command. Then, use the "system controller replace resume" command to resume the replacement operation.
- Syslog Message
NSO-based controller replacement operation from initiating node "%s" has been paused. Remote cluster node %s and remote cluster HA partner node %s are paused in %s task during %s phase for operator intervention.
- Parameters
taskName (STRING): NSO-based controller replacement operation from initiating node "%s" has been paused. Remote cluster node %s and remote cluster HA partner node %s are paused in %s task during %s phase for operator intervention
ndo.cr.nso.resumed
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation using negotiated switchover (NSO) in a MetroCluster FC configuration has been resumed.
- Corrective Action
(None).
- Syslog Message
NSO-based controller replacement operation has been resumed from node %s. Remote cluster node: %s, remote cluster HA partner node: %s.
- Parameters
ndo.cr.nso.started
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation using negotiated switchover (NSO) in a MetroCluster FC configuration has been started.
- Corrective Action
(None).
- Syslog Message
NSO-based controller replacement operation has been started. Local cluster node: %s, remote cluster node: %s (model: %s), remote cluster HA partner node: %s (model: %s).
- Parameters
ndo.cr.paused
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation has been paused by the operator.
- Corrective Action
- Syslog Message
Controller replacement operation on node "%s" is paused by the operator.
- Parameters
nodeName (STRING): Name of the node where the replacement was in progress when the operation was paused.
ndo.cr.paused.error
- Severity
ERROR
- Description
This message occurs when the controller replacement operation has been paused due to an error.
- Corrective Action
- Syslog Message
Controller replacement operation has been paused on node "%s" during %s task due to an error: %s.
- Parameters
ndo.cr.paused.userInput
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation has been paused for operator intervention.
- Corrective Action
- Syslog Message
Controller replacement operation has been paused on node "%s" in "%s" task during "%s" phase for operator intervention.
- Parameters
nodeName (STRING): Name of the node where the controller replacement operation has been paused for operator intervention.
ndo.cr.resumed
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation has been resumed by the operator.
- Corrective Action
(None).
- Syslog Message
Controller replacement operation has been resumed on node "%s" by the operator.
- Parameters
nodeName (STRING): Name of the node where the controller replacement operation has been resumed.
ndo.cr.started
- Severity
NOTICE
- Description
This message occurs when a controller replacement operation has been started in the HA group by the operator.
- Corrective Action
(None).
- Syslog Message
Controller replacement operation has been started. Node "%s" (model: %s), HA partner node "%s" (model: %s).
- Parameters
nodeName (STRING): Node name of the controller that will be replaced.
modelName (STRING): Model name of the controller that will be replaced.
haNodeName (STRING): Node name of the HA partner controller that will be replaced.
haModelName (STRING): Model name of the HA partner controller that will be replaced.
