net.ifconfig events
net.ifconfig.addLimitExceed
- Severity
ERROR
 - Description
This message occurs when the limit for adding logical virtual local area network (VLAN) and interface group (ifgrp) interfaces is exceeded. The latest attempt to add an interface did not succeed.
 - Corrective Action
Delete any existing unused VLAN or ifgrp interface and retry adding the new logical interface.
 - Syslog Message
The limit for adding logical virtual local area network (VLAN) and interface group (ifgrp) interfaces is exceeded. The maximum limit per host is %d.
 - Parameters
maxlimitperhost (INT): Maximum interfaces per host.
net.ifconfig.ioctlError
- Severity
NOTICE
 - Description
This event is generated when the ifconfig command encounters an error while attempting to perform an ioctl.
 - Corrective Action
(None).
 - Syslog Message
ioctl error encountered while configuring interface '%s' using ioctl '%s' (error string='%s', error code=%d).
 - Parameters
ifname (STRING): The name of the interface
ioctl (STRING): The name of the ioctl
errorString (STRING): The error string
error (INT): The internal error code
