The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
netif.ratelimitthreshold events
Creating your file...
Your file is ready
netif.rateLimitThreshold
- Severity
ERROR
- Description
This message occurs when the protocol rate threshold is reached on a network interface.
- Corrective Action
Fix the faulty network configuration or incorrect setup that enables a sudden spike in broadcast packets to bring down the node. If you still want a high ARP rate threshold, use the "bootarg.arp.ratelimit.threshold" boot argument to set that threshold.
- Syslog Message
High rate limit on network interface %s for broadcast protocol %s being detected: %d pkts/sec.
- Parameters
ifName (STRING): Name of the network interface that reached the protocol rate threshold.
protocol (STRING): Name of the broadcast protocol that overloaded the network.
packetRate (INT): Observed incoming packet rate per second on the interface.
