nodewatchdog.config events
nodewatchdog.config EMS events occur when bootarg.nodewatchdog.level is set to an invalid value.
nodewatchdog.config.invalid
- Severity
ERROR
- Description
This message occurs when bootarg.nodewatchdog.level is set to an invalid value. This can only be done manually. When an invalid value is set, Node Watchdog reverts to the default behavior.
- Corrective Action
Set bootarg.nodewatchdog.level to a valid value at the LOADER> prompt, or modify the value by using the "system node watchdog modify" command.
- Syslog Message
The value of bootarg.nodewatchdog.level is set to an invalid value, "%s." Node Watchdog reverted to the default behavior (%s).
- Parameters
bootarg (STRING): Value of bootarg.nodewatchdog.level.
defaultVal (STRING): Default value of bootarg.nodewatchdog.level.
