The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
oauth2.wsdb events
Creating your file...
Your file is ready
oauth2.wsdb.set.failed
- Severity
ERROR
- Description
This message occurs when setting the SSL trusted server CA path in web services database fails. Potential reason could be that the application is busy or unresponsive. This will impact OAuth2.0 user authentication.
- Corrective Action
Ensure all nodes in the cluster are online and healthy by running the "cluster show" command and verifying that the "Health" and "Eligibility" fields displayed as true. If true, retry the operation. If the issue persists, contact NetApp technical support.
- Syslog Message
Failed to set the SSL trusted server CA path in web services database.
- Parameters
(None).
