      pha.add events
pha.add.dev.limitExceeded
- Severity
ERROR
 - Description
This message occurs when an attempt to add a passthrough host adapter (PHA) disk to a virtual disk adapter fails because the supplied disk number exceeds the maximum supported disk ID.
 - Corrective Action
Reduce the number of devices connected to Data ONTAP® and retry this operation.
 - Syslog Message
Failed to add a device with unit number %d to virtual disk adapter. Reason: Supplied disk number exceeds the max number of supported disks.
 - Parameters
disk_num (INT): Unit number for the rejected disk.
