The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
rdb.open events
Creating your file...
Your file is ready
rdb.open.unit.error
- Severity
EMERGENCY
- Description
This message occurs when the cluster management data replication module encounters an error and fails to open the unit, causing the process to exit. The process should restart automatically with full service restored.
- Corrective Action
Verify that all the units are operational and using the "cluster ring show" diagnostic command. If the problem persists, contact NetApp technical support for assistance.
- Syslog Message
Module "rdb_module::module_init": failed to open unit "%s" -and is exiting the process to force a restart.
- Parameters
unit (STRING): Unit that failed to open.
