      repl.core events
repl.core.nanny.cleanup
- Severity
INFORMATIONAL
 - Description
This message occurs when a replication transfer that completed ten or more minutes ago is found and subsequently cleaned up.
 - Corrective Action
(None).
 - Syslog Message
The replication transfer identified by transfer Id %s was cleaned up since the transfer finished ten or more minutes ago.
 - Parameters
transferid (STRING): Identifier given for a particular transfer by the replication initiator.
status (INT): Progress status of the replication transfer when it was cleaned up.
failureReason (INT): Failure reason code if there was a failure. Zero is returned on success.
failureMsg (INT): Failure message code if there was a failure. Zero is returned on success.
failureMsgDetail (INT): Failure message detail code if there was a failure. Zero is returned on success.
